Media
Imported Item
Imported Item
2001 TMI Bullitt Rear Seat
Imported Item
Imported Item
made the fire wall my selfe butt welded the ford script in ,i will be painting soon. gulf stream aqua ,should be pretty.i have been collecting parts for it for about 15 years now ,trying to get the best i can, will not be much body work,in the prosses of gathering parts i have come up with enough parts to to build 4 more trucks
Imported Item
Imported Item
the J code 302 was a snug fit in the old truck i port matched and polished the heads, stainless valves with 3 angle valve grind,280 H comp cam prety hefty idle 10-1 forged pistons 77 clevitte bearings, torqer intake and a 650 holly double pumper, its enough horse power to tear it apart i want to replace the shifter in the 5 speed with a short throw, the mustand drive shaft was a perfect fit ,no cutting, the 65 mustang 9" was also a perfect fit , n case with detroit locker and 391 gears works perfect with the tall tires and the polished torque thrusts. i decided to keep the wish bone front ,but up graded with mustang disks,heavy duty shocks and a sway bar give a very good ride, as you can see a lot of it is mustang
Imported Item
Imported Item
just got new door panels ,have to fix a sticky window regulator and they are ready to install
Imported Item
Imported Item
this is the third black mustang with deluxe interior i have owned, the first was an Acode 66 gt fast back and a matching A code gt coupe. both with red pony interior but the 67 interior has to be the best with all that brushed aluminum
Imported Item
Imported Item
just finnished the heater box,the box had been painted black and it was scratched so i gently glass beaded it ,the paint came off very easily i then clear coated the case halves. its a bit brighter than the origional finnish but it looks like brand new. all the metal parts were removed, beaded and painted semi gloss black
