Media
Imported Item
Imported Item
you think you have a lot of parts laying around ,working on one car , try working on three at the same tim,pats in the tool box ,under the tool box ,in the cabinets on the cabnets. in the rafters .hainging on the walls, heck i even have them in my closet on my dresser under it and under my bed
Imported Item
Imported Item
brand new pop open gass cap
Imported Item
Imported Item
headlight light assembly bolted in, i am just using standard bolts on every thing right now on finnish assembly they will be stainless
Imported Item
Imported Item
the whole bottom of the trunk lid is finnished ,no exposed fiberglass.yet it looks like origional. the end caps are very heavy pieces and fit beter than any after market part i ever used
Imported Item
Imported Item
the only wave i could find in the fenders was at the bottom of the pass. fender, i believe its were the inner bracing is bonded in, it was actualy a high spot and it block sanded right off hardly even went through the gell goat
Imported Item
Imported Item
i realy like the side scoops,they bolt on instead of clipping on
Imported Item
Imported Item
69 ram air hood ,this is a major nice piece,purchased all the fiberglass from stang-aholics, i had another hood from lets just say T.B. left it setting in the sun one day ,just about bowed around the bench it was on, when i picked it up i could almost punch my fingers through the underbracing it was so soft
Imported Item
Imported Item
my tail light pannel for my 69,stang-aholics unit new ford tail lights and frames, i have seen the license plate lights go for crazy prices on ebay. did you know you can buy them at nappa autoparts for around $5. each
Imported Item
Imported Item
picked up the exhaust collector from branda nice,even has shelby part #
Imported Item
Imported Item
i found an intake manifold for Johnnys car its an edellbrok f-427 , never saw one before i was told they are hard to come by. hope its as good as the f-4b small block is
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
Imported Item
walk through floor
Imported Item
Imported Item
seeing it like this will almost make u cry
Imported Item
Imported Item
Imported Item
Imported Item
Pin-up girl on hood scoop "lucy Quipment"
Imported Item
Imported Item
Horse tearing out
Imported Item
Imported Item
Mustang at Palm Springs Concours
Imported Item
Imported Item
2008 Mustang Gt P51 theme car
Imported Item
Imported Item
Imported Item
Imported Item
all aluminum fender wells and rear tub
Imported Item
Imported Item
interior all stripped down with all aluminum floor pans
