Surely you're gonna do something to that dog house header panel, I don't see you leaving it all wavey/wonky like that. Covering it up?
Or are.my eyes deceiving me?
It will have to slow down to hit 88 mphJust wait until this hot-tub time machine hits 88 MPH.![]()
Thats where the machine guns are coming outSurely you're gonna do something to that dog house header panel, I don't see you leaving it all wavey/wonky like that. Covering it up?
Those sure would be handy on the roads nowadays.....Thats where the machine guns are coming out
With a little practice, you can get them so that they careen off the road, out of the way.Those sure would be handy on the roads nowadays.....
Machine gun maintenance covers.At first I thought you were going to try to make a rear window louver, then I thought maybe it was for a heat extractor hood... THEN I figured out those are engine bay smoothing panels, lol.
Yep. Had a bunch of peopleAt first I thought you were going to try to make a rear window louver, then I thought maybe it was for a heat extractor hood... THEN I figured out those are engine bay smoothing panels, lol.
It's soooo smooth! Damn, art work man!
So how much weight does this add to the nose of the car? Just curious if you know.
PFFFTTT!!!! This is just the first round of about 100 primer coats (trust me, I know), and that is how it is magical.I want this magical high build primer that does all the filler work since it goes from epoxy to that...
We cut out alot of metal and then plate it so I doubt its adds much. Like the stock firewall metal is all cut out and gone.It's soooo smooth! Damn, art work man!
The stuff Im using is basically sprayable bondo but is direct to metal as well. It requires a 2.0 tip and your looking at a half gallon. To startI want this magical high build primer that does all the filler work since it goes from epoxy to that...
Maybe .75 gallons with that run in the 2nd to last pic! Doesn't matter though, it's all gonna end up as dust on the floor anyway.The stuff Im using is basically sprayable bondo but is direct to metal as well. It requires a 2.0 tip and your looking at a half gallon. To start
You bet man. We hosed it on. 90% will be blocked off and prime…prime again. Like this guys bay. Know him?Maybe .75 gallons with that run in the 2nd to last pic! Doesn't matter though, it's all gonna end up as dust on the floor anyway.
