I herd that you need to change the inner and outer tir rod when using these spindles due to them sticling oout farther. Is this tru? I allready have them installed and waiting on wheels and need allignment.
Dont switch them out, they spindles you have on there are fine. They will produce a 8mm wider track, all of your stock steering components will be fine. One thing you should look at updating is your ball joints (that is if you havent) when i did my swap I used SN95 ball joints instead of using washers on the stock ones.
