  • SN95 4.6L Mustang Tech
'02 GT Intermittent problem (Reward for help)
  • Thread starter Thread starter stangsdado
  • Start date Start date Aug 19, 2009
  • 3
First Prev 3 of 3
stangsdado
36
#41
  • Aug 21, 2009
  • #41
Mizark347 said:
As I stated earlier I had the same problem with my 02 GT. I installed a set weapon X COP's and problem solved. How many miles are on it? Have you washed the engine recently? My car didn't throw any codes at all. I also pulled each connection to all 8 coils and each one made the engine stumble. Sounds like a weak Coil.
I think you're right. However, now that they've been cleaned and dried, the car's not doing the vibration anymore. New spark plugs may have been unnecessary but the car's going to a good friend of mine so I'm not bitter.
Working on the ABS problem now but I have no idea where the sensors are. I've done all the breaks on this car so I'm familiar with it. I've even done one caliper when it started leaking brake fluid but I've never paid attention to any sensors...
bullitt 736
120
Magnolia, Texas
Aug 23, 2009
#42
  • Aug 23, 2009
  • #42
Check the sensor connections and clean them. Chances are its probably the ABS module.
stangsdado
36
#43
  • Aug 23, 2009
  • #43
Damn. That sounds expensive.
stangsdado
36
#44
  • Aug 24, 2009
  • #44
OK. So I took out every single wheel sensor, cleaned them, tested resistance to 50 ohms as specified, put it all back together and the ABS light is still lit. Can I reset this somehow? Any way to get codes other than going to the dealer? Can anyone understand this page?
Mustang 1998+ ABS Diag Info
tag4car
Birmingham AL
Aug 25, 2009
#45
  • Aug 25, 2009
  • #45
there is a test plug on the bottom of the abs module, make sure its seated well. Also, Check brake fluid level
stangsdado
36
#46
  • Aug 25, 2009
  • #46
So I called up my long time mechanic (owner) and he said he'd scan for me for $35. As I was pulling in, I see him leaving so I knew I'd have to deal with someone else. So I walk in, and his son takes the car. He comes back and tells me the ABS Control Module is most likely fried cause there is no communication. Just as I was about to call it quits, Frank (my mechanic) walks in and tells his son to take a deeper look. So his son breaks out the wiring diagrams and checklists and such and finally finds out that there is no power to the module upon ignition. He checked the ground and the fuse and those are good. Frank tells me it'll be $75 per hour until he finds out where the problem is.
I took the car back thinking I'll look at it but I think I'm going to just take it back to him and hope it's a 1-2 hour job.
Any opinions?
mogs01gt
3,113
30
119
Ohio
Aug 26, 2009
#47
  • Aug 26, 2009
  • #47
First, remove that 255 pump. There is no reason to have it and it probably is hurting your car. Second, clean your IAC and replace your TPS. Also, replace your fuel filter.
With the leaky coolant, sounds like you have a cracked intake. Get some starting fluid, spray it around your intake. If you car rev's, you either have a vacuume leak(cracked vacuum line) or you have a cracked intake. Its hard to determine the issue when you have that 255 pump though.
To test the ABS, go out on a empty street and slam the brakes on. If it locks up, its ABS, if it doesnt, your ABS is fine.
  • 3
First Prev 3 of 3
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
  • Gulftown980x
  • Jul 29, 2026
squeak93
