StangLou
Yeah man I plan to, just the gear install, chip, and custom program set me back a bit
. Im hoping I can get up to the dyno in a couple of weeks and do a little tune session after my funds get a little better. I let my gas run down to like 1/4 of a tank then filled it up with premium after the chip install, but its still spark knocking a touch at really high rpm, so I think I need to lower my timing just a bit. Im going to burn this tank out then fill it up all the way with premium, and if that dont help then I will definately be going to get a full tune/dyno just to have some before and after #'s.
About your problem, Im with these guys above now, the only other thing that comes to mind would be the tps. I dont really think a throttle body would help a stock stang overcome this, it might even make it worse. This sounds dumb, but Im not sure what the heads on 99+'s are. Are they aluminum or did you just put some aftermarket heads on yours? Did it start this problem after you switched heads? If so then the new heads might be a bit starved for air with the stock intake and throttle body assembly. Most aftermarket throttle bodies use the stock tps though, so you still might have to get a new one of those. I think the ford motorsport 70mm tb comes with a new tps Im not sure
Thats all I can come up with for now lol, gotta get ready for work
Last year it started to snow on like Nov. 2.
From what I've found the FoMoCo 70 mm is the only one the includes a new T.P.S. If I don't come up with anything else, my might go that route, thanks to our Canuck Mustang friend. :canflag:
Plus, the analytical/engineering mind that I have won't rest until I resolve this matter
...Thank you! :canflag:
I'm passing along a copy of it to some of my friends who are working on the GM fuel cell project...
