SOLD '05-'14 Mustang Bmr Lca Relocation Brackets - Nib
2005 to 2014 Ford Mustang BMR Rear Lower Control Arm Relocation Brackets. New In Box. Looking to get $95 shipped.
Improves Traction. Correct the suspension geometry of your S197 Mustang with BMR Suspensions Control Arm Relocation Brackets to improve drag strip traction and handling traction exiting turns. The perfect addition to a set of BMR Rear Lower Control Arms
Quality Construction. Made in the USA from 3/16" CNC laser cut steel plate for strength these Relocation Brackets are completed with a long-lasting black hammer-tone powdercoat finish, and are designed to be an easy bolt-on using existing mounting holes, no welding or drilling is required.
Application. This pair of BMR Rear Lower Control Arm Relocation Brackets are designed as a direct bolt-on upgrade for all 2005 to 2014 Mustangs, including the V6, GT, Bullitt, and Shelby GT500 models equipped with BMR Suspension Rear Lower Control Arms. Technical Note. When installing with stock factory rear lower control arms, modifications may be necessary to position control arms in upper mounting positions.
