07 427 Built
Apollo427R
Street/road racing intent. Will be running E85. My questions are. Do I need long tube headers even though I have shortys with not cats? Is there anything else I might need or should have? What fuel filter do I need for E85? Will this be a good setup??
Current setup:
- FRPP 4.10's
- 4" aluminum DS
- ACT heavy duty clutch
- mcleod hydraulic throwout bearing (blown)
- BBK shorty headers/ no cats off road H-pipe
- 2.49 pulley/ steeda CAI
- roush tensioner
- AFCO duel pass heat exchanger
- FRPP 62MM TB
- MSD street fighter coils
- FRPP hot rod cams
- GT500 HE coolant pump
- drilled and vented rotors
- JMP tune
Already purchased awaiting install:
- RAM adjust TB/ braided steel lines/ new steel master
- roush heavy p-51 clutch disc
- FRPP HP pilot bearing
- FRPP GT500 strut mounts
- UMI sub frame connectors
- steeda x brace
- SR front strut and rear shock tower braces
- A arm support brace
- SR performance 8 point rollcage
- VIS racing carbon fiber Super snake hood
- Walbro 400 lph fuel pump
- FRPP 80LBS injectors/ rail spacer kit
- freedom racing cam phasers
- A/C delete kit
- Hoosier A7 295 rears 275 fronts
