$1,000 for mods, what would you do?
Ok, I've socked away about a grand for some mods to the 2000 GT. Currently, it is bone stock. What would you do with $1,000, not including gears. (I've got both 3.73's and 4.10's at home, just haven't decided which to do yet.)
I was thinking an programmer (Diablo maybe)
O/R x-pipe (Don't know if this will affect emissions passing yet)
Shifter
Pullies.
Any other combinations I should look at? This is used as a daily driver. But then, my commute is only 7 miles each way.
By tune up I meant making sure all the fluids are fresh, maint has been done, etc...
But anyways, I think you should try to do gears and handheld programmer. If you have any left over do a catback or even cheaper some weld in flows.
You should try to work a short throw shifter in there also.
Cool. Maintenance is well kept, all fluids have been done within the last 5,000 miles.
Gears, like I said are easy for me, so I figured a programmer so I can recalibrate the speedo.
I've read (not experienced it though) that a crossover pipe will gain more power than a catback. Also that a CAI wouldn't increase that much more than a K&N (my only mod)
Shifter, for sure. That's primarily personal preference, I hate the stock shift.
It is different for me to be modding a vehicle that isn't to build as slow as you can go. (crawl ratio on the Samurai is around a 132:1) I'm used to gearing the snot of a rig, and building flexy off-road suspensions.
Thanks for the ideas!
Sounds like you're on the right road! Those li'l Samurai's are a lot of fun!:nice:
Skip the "tip-tap" mods and sock away another 3-grand and buy yourself a blower for some real power.
