1.8 60 fters, whats it take?
what will i need to do to pull 1.8 60 ft. times in my 87? ive allready got 4.10 gears and 275/50/15 nittos. will i be able to do it with control arms kyb shocks and struts 4 cylinder springs and full length sfc's?
thx in advance.
A non-slipping clutch, dr's (nittos will do it), 373's or steeper, and a bit more power than stock and you should get it pretty easily with a good 5spd driver that can work the clutch/gas pedal nicely:nice:
5.0fox - Yeah you can do it...just heat those Nitto's up (2nd gear burnout held for 5-7 seconds). You will feel/see the rpms drop as the tires heat up and try to grab. The Nitto's will grab good...you can pull a 1.8 60ft:nice:
5.0fox said:
sweet maybe ill be able to do it next friday when i run it. any other tips?
heat em a little more after you think they might be heated....
and don't do a pu$$y 2k burnout...use 2nd gear and tach it up
start counting when you see smoke rolling good.
don't do a dry hop, stage deep and launch it hard on the last amber...try 3000 then step it up 1k or so for the next couple runs. (unless you break loose too bad on 3k)
should have no trouble at all , if you do, you need to make it hook and probably heat them longer
