1/8th mile times
  • Thread starter Thread starter 90five0oh
  • Start date Start date Aug 5, 2007
9
90five0oh
29
i live in robertsdale, al
Aug 5, 2007
  • Aug 5, 2007
hey guys i was jus wondering if you could help me out on lowering my 1/8th mile times. you can look in my sig for my mods. but my best 60ft is a 2.03. im running street tires at 18psi. i cant get it to hook for nothin. but any help is appreciated. thanks.
foxmustangman
196
Idaho
Aug 5, 2007
  • Aug 5, 2007
Get an exhaust cutout right before your x-chamber.
Fett
766
  • Aug 5, 2007
Tires, you need tires. Either MT street drags, or get a set of slicks. I personally think running at the track on street tires is a waste of time. You wouldn't run a sprint wearing flip-flops....you shouldn't run at the track with street tires.
Shamus O'toole
18
Florida
Aug 5, 2007
  • Aug 5, 2007
When you go to the track try unbolting your front sway bar.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Aug 5, 2007
  • Aug 5, 2007
a set of tires makes all the difference. i remember the first time i made a pass with sticky tire i about crapped my pants. its a different feeling deal when you dump the clutch at 4k + and the car dead hooks instead of spinning.
9
90five0oh
29
Aug 6, 2007
  • Aug 6, 2007
i knew the tires would help out a lot but the sway bar thing doesnt make that much or a differnce. cuz i took it off loast time i went and this time it wasnt any different. but im only launching at about 2800 rpms to keep from spinning right off the line. it will hook decently when i do that but theres still some spinning. and the sreaon i am running street tires is becuase this is also my DD. i jus like to play at the track on fri nights
Shamus O'toole
18
Florida
Aug 6, 2007
  • Aug 6, 2007
Removing the sway bar should allow your car to transfer wieght to the rear. You must be running a stiff rear shock. Get adj. rears and adjust them to allow the rear to squat a little.
9
90five0oh
29
Aug 7, 2007
  • Aug 7, 2007
well the rear shocks are factory replacements so im guessin they are pretty stiff. but i plan on gettin some 50/50s to put on the rear so i can transfer the weight
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Aug 7, 2007
  • Aug 7, 2007
IIRC the factory shocks are around 50/50 so that wont help too much. what will help is a set of 90/10s in the front, will let the front end come up and more weight transfered to the rear of the car.
1/4 Horse
577
Bear, DE
Aug 7, 2007
#10
  • Aug 7, 2007
  • #10
You really shouldn't run any less than 20psi on street tires. The tires can cup and make traction worse. When I owned my 86 I actually got the best results at 24psi, driving around the water box and slipping the clutch. I was able to consistently pull 1.9 60 foot times.
Shamus O'toole
18
Florida
Aug 7, 2007
#11
  • Aug 7, 2007
  • #11
Nice looking Fox!!!/\/\
blackened88lx
Connecticut
Aug 7, 2007
#12
  • Aug 7, 2007
  • #12
1st step, don't listen to him.
Remove the front sway bar, don't just disconnect it, it's a decent chunk of weight too. Relocate the battery to the trunk. Get some good drag radials, M/T ET Streets or BFGs work great. Shocks. Master the launch, then powershift the **** out of it.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
