If you are using 20+#'s of boost I would sure hope you are using an intercooler. To run 10's I wouldn't think you would need that much boost though, I'm sure you could run 10's with 12# w/o an intercooler.
When referring to more hp at higher RPM and your powerband, I would think most of that is dictated by your cam. Your S/C will provide max boost at your shift point, which will be based on your cam. Just because you have a S/C doesn't change your powerband. Change your pulley if you want more boost at the same RPM.
