10 Second sn95 ?
SHOJOE
20
Maryland
My name is Joe, I live in Maryland and am 20 years old. I am on a quest for 10's in an sn95. At the moment I dont even have a mustang I drive a SHO. In the past I had two mustangs a 1995 GT and a 1985 5.0 (really miss those cars). I am going to build a strip sn95 looking for mid 10's and want everyones point of view on whether you think my setup would get me there. And what I should do and not do. I am not the richest kid (work at pepboys), but I have patience for the build. This is something I really have been longing for. This is just some of the things I had in mind to get on track.
Chasis
v6 sn95 chasis
UPR Front end k-member kit
UPR Rear End kit Anti roll, ALCA's, AUCA's, torque boxes etc
Moser 31 spline 8.8 spool kit with axles, spool, c-clip eliminators
UPR Full length subframe connectors
Manuel steering rack
GT Rear Springs (airbag in right rear)
Aluminum Driveshaft
Solid Motor mounts
Full roll cage
4.10 or 4.30's (in rear end?)
Lakewood 90/10 Front
Lakewood 50/50 rear
Engine
351W .030 over
Rebuilt bottom end built to factory specs except forged pistons
AFR 185 heads Or TFS
Edelbrock Vic Jr Intake (I want carbed!)
Holley 750 Carb
BBK L/T's
1.6 Scorpion RR's
Jay Allen Custom Grind Cam
Nitrous 100 first stage and 200 second stage
Redneck Racing c4 tranny
I need help on my fuel system not to sure what regulators and pumps I should look in to. :flag:
I'm wondering about the 'factory spec' bottom end. I'm thinking you'll need 500+hp to get in that range, but I'd imagine that would be pushing a stock bottom end too far, even with forged pistons.
BTW, he DID mention he's going carb.
I see alot of stock bottom end 302's going 10's. I chose the 351 route becasue of the added rigidness of the block and the added cubes. I am going carb'd
by bottom end "factory specs" are you saying you would be staying at 351 and about 9:1 compression?
seems to me that stroking it to 393 or 408 would get you there alot more easily, epsecially if you are staying NA
also, you might consider pro magnum rockers because they fit under stock height valve covers, which might help with the fitment of the intake and carb and stuff like that
lastly, if you are using hydraulic lifters but you get a block that was not made for hydraulic lifters, you will need to add link bar lifters to your list of things to get. i'm not sure if that holds true for solid roller lifters or not.
i actually have a motor that would be a great start for you, and i'm in maryland too, but i hear you about the finances thing, and it is probably out of reach for you at this time. i also have a 750 carb and a rpm air gap intake and some other carb stuff for it because i was going to go carbed at one point
i'm selling my engine (and car) to finance the restoration of my 67 fairlane
I don't see a reason it wouldn't go WAY into the 10's with the spray on it. I'd expect it to be a mid-high 120mph car NA if you kept the weight down as it appears you will. With the squeeze on it, it should trap in the 130mph range if setup correctly.
I'd personally go with an AFR 205 at a minimum and an Ed Curtis cam, but that's me. :)
Is the car in your sig your old one? if so, what did it run? I see it had skinnies on it so I assume you had it to the track.
dead on agree. if i went through the trouble of putting in a 351 based engine, id go to 408 personally. 10's wouldnt be a a problem with a 408 on 200 shot. my buddy omar went 10.80's with a 357 and 100 shot.
a 351 will handle more poer than 500.i have a friend with a 95 lightning complete stock motor and a nice turbo and it lays 660 to the tires.he also has the 2000ish lightning and make a tad over 700 with a vortech on it.
Nice.
Yes, I am going the nitrous route instead of turbo because of the cost factor. Unless I am able to get my hands on a nice used single turbo setup.
I went 10.89 with 347 and little d-1 procharger!Now in the 9s with F-2 and 408.The more you spend the faster you can go!!
aint that the truth!!!i got tired of spraying all the time plus refills get expensive!!! ive used a whole bottle on 1 hit!hahaha. the charger is nice, you dnot have to worry about anything (to a certain extent) but i got a small shot of gas on top:eek:
i had a 150 shot on my car. it was good for about 4 or so runs down the track keeping goood constant bottle pressure
