Ok. I bought a new mustang. 1998 GT. The car is fully built. Here are the mods. (I listed everything engine/drivetrain in case you have questions). There is a ton more suspension mods as well but that's not applicable.
4.11 Gears Ford Racing
Rear Diff Cooler
Trans Cooler
TKO600 Trans
RAM Clutch
Aluminum D/S
Aeromotive Fuel Pressure Regulator
Steeda fuel rail
Meizure ELec Water pump
Griffin Radiator Aluminum
Elec Fan
Oil Cooler
Oil Temp Gauge
Fuel Pressure Gauge
Accusump
42lb injectors Ford Racing
Logan Motorsports Aluminum Intake
Cobra Twin T/B
Larger (unknown brand) Mass Air Meter with K&N filter
Moroso Oil Pan 6 qt
Livernois Stage 3 heads Custom built cams (no specs
Explorer Block 4.6 Alum block, mahle pistons with relief for valves
Long tube headers
Magna Flow exhaust
SCT chip (Chip)
Pro 5.0 shifter
Ford Racing wires
MSD coils
The car is tuned for 100 octane and is at 11.2:1 compression. I have heard conflicting shops say that it is impossible to tune to pump gas for fear of detonation. Others say it will be fine. I would like pump gas, but understand that might be impossible. Also, if possible, what tuner would you go with. The only shops are here use Diablo for their dyno tuning. Also, could I tune it myself with software on a laptop and the handheld tuner???? Needs some advice.
Also, it made 351 rwhp and 307 tq if your wondering.
Mike
Rear Diff Cooler
Trans Cooler
TKO600 Trans
RAM Clutch
Aluminum D/S
Steeda fuel rail
Elec Fan
Oil Cooler
Oil Temp Gauge
Fuel Pressure Gauge
Accusump
Cobra Twin T/B
Moroso Oil Pan 6 qt
Long tube headers
Magna Flow exhaust
SCT chip (Chip)
Pro 5.0 shifter
Ford Racing wires
MSD coils
Mike
