14 x 7 Cragar s/s w/235 60 14 tires on 66 mustang.
Did a little more research.
I looked up dodgestangs website and found that my desired setup (235 60 14 on Cragar ss) would require a 3.5 back spacing but would need the fender rolled. However it does not list the stock backspacing. As of now I have the same tire size on a set of "smoothie" rims w/ no fitment issues. I have no idea what the back spacing is on the smoothie rims. It is possible the fenders have been previously rolled in the past but I have know way of determining this.
Why dont you measure the backspace of your wheels you have now:shrug:
+1
If you already have the tire on a different wheel and it fits with no issues on the car as is. Just get the measurements from the rims you have and get a different set at the same measurements. Should have no issues that way. Just take the rim to a tire shop and have them check it out for you, or lay it down and use a straight edge and tape measure. Try here it says how to measure. Backspacing measurement guide
