17x9 03 cobra tire fitment help!
91stang50GT
57
i just purchased a set of 17x9 4 lug 03 cobra replica wheels. The wheels are 18mm offset with 5.70" backspacing. I was wondering what is the largest tire i can run up front and out back without rubbing issues or dealing with rack limiters.
Additional info- It is a stock ride height 87 gt, with aftermarket control arms and no quadshocks
thanks!
I would personally run 275's out back, but there was a guy on here that had a set of 315 nitto's on his rears..looked bad ass, but all tires are different. For a 9" wheel I'd run a 275. Up front, to try to reduce as much friction as possible, I'd run at most a 255
hmm.. anyone else have any experience or opinion on the subject? Id like to run 275 out back if it will fit but i know 18mm offset isnt very common.. and i've also heard 87-89 front inner fenders are smaller than 90+ so should i expect any rubbing with 255s?
go 235 front. I have 245s and have had some rubbimg issues that I think have been worked out. 275 rear or 315 nittos should fit with some clearancing. I believe that mine are a 26mm offset/6" backspacing.
