I know different motors like more or less heat, I know mopars dyno better with colder water temps in general... what about fords? Any down sides to going to a 180?
. I figure if it's a little too cool the ECU will be turning fan on and off anyways...I figure if it's a little too cool the ECU will be turning fan on and off anyways...
in there. It wouldn't even fit in the thermostat housing the right way so they had put it in backwards. With the 180* stat it stays around the "N" which it should, oh and the fan kicks on right after the first mark which is probably at 180 or lower...hmm...with my Fluidyne radiator and 195 t-stat, my water temp doesn't go over 180-185 degrees even in 90 degree weather. With the 180 t-stat, it wouldn't even warm up enough and was running 150-160 degrees![]()
Huh? The T-stat is what regulates coolant temps. You have to remember that the coolant temps vary widely throughout the system. Depending upon where your gauge sender is, there can be a difference right there (same gauge, same sender will read differently in different locations).
ya i'd have to agree with that, and add that maybe your gauge is wrong... I don't care how good your coolant system is if the stat isn't open it's not going to work.
