180* Thermostat Question
vld
132
My Issue:
when she is cold she has good power from idle; will bark the tires from a hard launch every time, good throttle response etc. when she is hot she is so weak from idle it almost feels like i am launching from second, no bark, slower throttle response by comparison generally sluggish performance. as i get up into the rpms power comes on but from idle she is a dog when the engine is hot.
My Solution:
I went to buy a 180* thermostat to see if this would help my problem. counter guy said he would not suggest this as the ecu and all onboard systems were designed around the 195* t-stat and drivability would suffer. is this right?
jeffnoel said:
I disagree there are way too many guys on here that are running a 180 no problem. Just use your Predator to set the fan to come on earlier with the 180 thermostat.
:stupid: i agree with getting a SCT or diablo programmer to change the temp the fans come on, in order to work with the 180* T-stat... Thats what i have a 180* T-stat and reprogrammed the fans
DTNODYA said:
It made my car overheat at idle on hot days. :shrug:
not unless it was a bad t-stat. all it does is allow the coolant to circulate to the radiator sooner. so when the engine hits 180*, it opens up instead of 192*. as long as the t-stat is open at or before 192*, the car won't overheat unless something else is wrong.
Black Stang 97 said:
i am also wanting to change my t-stat to a 180*...what brand and from where do you guys recommend?? i bought one a while ago and made my car almost over heat, so i returned it...
I got a ford one made for the latest retired Lightning truck. Went down a full letter in the word "normal", so I know I'm running cooler, just not sure how much. No chip so the fan still comes on later.
Yeah, I know ... and after a while it is only hot coolant being constantly circulated and when my car is stopped (no air cooling the coolant in radiator) it would overheat.
I should buy a tuner so I can adjust crap like that but yeah, that was my issue.
McTeague said:
I would agree with the parts counter guy, your car is tuned for 195.
Also, do not get on your car when it is cold dude! :notnice:
yeah, i know. i dont do it much, it just the only time she really has any off the line kick.
triggz said:
180* tstat here for a long long time. I eventually got a predator and tuned it, and it helped more (have an autometer water temp gauge to monitor).
can you give me a quick run down of what temps to set the fan speeds for? there are several settings for on and off temps and i want to make sure i get it right.
vld said:
can you explain?
the reason for the t-stat is to allow your engine to heat up faster. this reduces engine wear and i believe helps emmisions. the t-stat prevents coolant from circulating until it's temperature has been reached. once the t-stat opens, it allows the coolant to circulate which helps hold the engine at operating temperature. so the t-stat will open at 180* or 192*, whichever t-stat you have. regardless, if you have the stock tune, the low speed radiator fan comes on at 206* and the high speed fan comes on at 220*. the benefit of the cooler t-stat is that it opens up sooner which means you can lower the temps at which the fans turn on in an effort to keep the engine cooler.
it's not the t-stat! if your car is overheating when idling, your radiator fan probably isn't working or your coolant level is low. it's unrelated to the t-stat. if the car overheats with a 180* t-stat, it's gonna overheat with the stock one too.
10-4. thanks:nice:
