Hi All,
Ok so I'm taking my block and crank in tomorrow for mag and decking etc
. My block is a 1987HO roller but I want the engine to run on carb not EFI (nostalgia). I have a timing cover from a 1965 289 and am thinking this may work on the 5.0 to get the dipstick up front and accept the fuel pump etc.
I can't seem to find any clear answer on this. A few websites that say yes it will bolt right on but then when I place mine against the 5.0 block I find there's dowel pins on the 5.0 block that will need to be removed (any idea how?). Or do I drill out the timing chain cover so the dowels will fit and then not put a bolt there?? I'm wondering if anyone has clear direction on this?
Other notes:
I will plug the old dipstick hole with a wooden dowel or may tap it.
I will use the 50oz imbalancer
Q1 - any suggestions on something I'm missing or steps to take here?
Q2 - What water pump should I use with an old timing cover? Reverse rotation or not?? Weren't 5.0's a reverse rotation pump?
Thank for any help you can provide.
. My block is a 1987HO roller but I want the engine to run on carb not EFI (nostalgia). I have a timing cover from a 1965 289 and am thinking this may work on the 5.0 to get the dipstick up front and accept the fuel pump etc.I can't seem to find any clear answer on this. A few websites that say yes it will bolt right on but then when I place mine against the 5.0 block I find there's dowel pins on the 5.0 block that will need to be removed (any idea how?). Or do I drill out the timing chain cover so the dowels will fit and then not put a bolt there?? I'm wondering if anyone has clear direction on this?
Other notes:
