1965 Fastback Mustang Project
We have a new rear panel so Brian removed the old one. This will save a lot of time.
After the panel was removed he had to make a patch for the front trunk floor
After Brian cleaned up the plug welds
Now that the rear panels fit it is time to prep the frame rails. As Brian was cleaning the front trunk floor he found a few rust pin holes. He cut out the bad area and made three patches one at a time to keep it from warping the edge that hangs down.
Brian ground all the welds on the patch than brushed a heavy coat of epoxy in the frame rails
Left side trunk floor welded to the rear frame rail
New rear panel with package tray test fitted and also the quarters and taillight panel installed before the rear crossmember is welded. We wanted to make sure everything lines up in the rear before the rear crossmember is installed.
Rear crossmember welded to the trunk floor and rear frame rail
Rear trunk floor prepped for epoxy primer
Epoxy primed
Rusty, question for you
The cowl area, how you put the patches in the holes, how much time did that take? And where does the heater draw its air from now?
I like that look, you got me thinking about it.
Brian makes a pattern out of poster board than transfers to steel and butt welds it using magnets to hold in place or you can use these clamps I got on ebay
The car will have AC and with the kit they supply a blockoff for the fresh air.
Brian made a few patches than cleaned everything and epoxy primed
Starting to put the puzzle back together
Brian has to make or patch the inner structure since it is not available.
Next epoxy before making another patch
