1965 mustang with a 289...where does the negative battery cable go?
CaliKev
Putting my car back together and have no clue. does it bolt to the frame?...to the block? If someone can post a picture that would be much appreciated!
Thanks,
Kevin
I believe it bolts to the block, but you can do either one, frame or motor. My 90 bolts to the block and theres a large ground between the block and the firewall.
Matt
I had mine just bolted to the block but would have trouble with it starting after it would sit for about a month, so I had run another braided cable from the back of the passanger head to the firewall and haven't had a problem since.
