Progress Thread 1966 6 cylinder clutch problems. Need help
Mr.Smith
20
Washington
I bought a father son project. For my sons first car. The previous owner had the transmission bolted in but the clutch and shift linkage were not hooked up. When I went to hook it up I found that the rod that went from the throw out bearing lever to the linkage was about 2 inches short. I called him and he said he didn't know why that would be of course. So I got a few other things hooked up and went ahead and started it. I heard this clank clank clank like something in the clutch area was hitting something. I took the trans out and found no reason for the rod to be short and no signs of anything hitting anything. I haven't taken the clutch off the flywheel yet but it appears to be new. Anyone have any thoughts on why this would be happening?
The best thing to do when having this problem is to remove the tranny/clutch/throw-out bearing/arm and check everything yourself before reinstalling it. Look inside the transmission for trouble and get the clutch-arm adjusted properly. A shop manual helps. My 65 SIX is an automatic but I had a 67 standard in 67. Better to pull everything now and save trouble later.
