I'm trying to piece together all of the components for the A/C in my '66 coupe. The previous owners had removed most of the A/C related items from under the hood, and left them in the trunk. They also replaced the correct alt. bracket with another type. I bought a new bracket (idler bracket with the pulley), but I need help mounting it. There are two bolts which hold the bracket to the water pump. From pictures I've seen, it appears that there should be a spacer on at least one of these bolts. Can anyone tell me how long this spacer is? I have a spacer which the PO had used on the other alt. bracket. It measures 3/4" in length. Is this the correct spacer?
