1966 Ford Mustang
Takt
48
Madison, WI
1966 Ford Mustang - SOLD
* Motor new in 2009 - 347 (302 stroked and bored out .40")Details below
* Body work/paint in 2008, new hood 2010 (Color is Black Cherry) and had the drip rails shaved. There is a minor chip out of the rear of the car (one of my daughters hit their bike against it) and minor chip near the chrome window moldings (with are also new). I have the paint the body guys used for the hood, so can touch up.
* Interior new in October 2011.
* Trunk boxed in for sound system with Rockford Fosgate amplifier, sub woofers and 6x9 speakers.
*Rearend is 8" posi with 3.8 gear ratio
* Front breaks are disc converted and rear are drums
* Wheels are American Racing and tires are in great shape
Engine Specifications
Displacement 347
Block 302
Comp.Ratio 10.2:1
Heads Strike Force Aluminum Heads
Camshaft Erson E212024
Crank 3.40" Case Steel 3.4" Crank
Rod Forged I-beam 5.40" 2.123" ROD JOURNAL .927" BUSHED PIN
Pistons 4.040" Hypereutectic, Flat Intake Edelbrock
Carb Quick Fuel SS 650CFM Racing Carburetor
Fuel Pump High Output,Chrome
Radiator Aluminum 3 RowFan Flex Fan
Distributor Pointless
347 Stroker bored .040 over with 10.2:1 compression, aluminum heads, flattop hyper pistons, cast steel crank, forged I Beam Rods, .480 lift cam, 2.02/1.6 valves, 200/60cc
Professionally built in Fall 2009 by Performance Engines in Madison, WI
Exterior Black Cherry PearlcoatShaved Drip RailsInterior Black carpet, black rear seat, black headliner, custom Door Panels (black and cranberry), cranberry dash pad, black kick plates.
Drivetrain C-4 ATM - 8" Posi 3.8:1 rear.Hurst V-MATIC 2 DUAL MODE SHIFTER
Brakes Front disc brakes and rear drum brakes
Wheels/Tires American Racing Wheels
Trunk/Audio 2 - 12" Rockford Fosgate Punch SubsRockford Fosgate 4Channel 600w Amp Trunk boxed in with clean audio look
Car is located in Edgerton WI. Buyer responsible for pickup. I'm willing to help with delivery of car up to 150 miles (@ cost of $0.75 per mile) one way.
