1966 Mustang Needs A Little Work
Brian finished patching the left inner rocker
Test fitting the floor and it fits great!!
Fitting the toe boards
Last patch on the right rocker
Now he is making the last patch on the left side. Everything is epoxy primed first
The A pillar was damaged in the accident and that is when we found the rust
We used the other 1966 convertible we are restoring to make the jig needed for this project.
Test fitting the rear frame rails
Fitting the trunk floor pan
Fitting the floor pan
The frame rails have been welded but everything else is just screwed together at this point.
The last time fitting the panels before taking apart and welding the inner structure
Brian welding an inner support
Before Brian could install the outer wheelhouse he had to modify the opening. This was taken before he ground the welds
One piece outer wheelhouse installed
