1967 Mustang
  • Thread starter Thread starter USAF46270
  • Start date Start date Sep 28, 2007
U
USAF46270
46
Sunny Florida
Sep 28, 2007
  • Sep 28, 2007
My Stang came with a 289, I have a 390 that is being given to me.
They cam with a 390, what do I need to bolt it in?
the ford part number are for frame 6028 r.h.
6029 l.h
now the intermead plat 3038
next is the motor mounts 6046 r.h
6046 l.h.
are these the only ones I need to put the 390 in?
thanks
p0prcksandc0ke
111
sacramento,ca
Sep 28, 2007
  • Sep 28, 2007
i think thats all u need but before you put it in make sure you put new spark plugs in its not fun changing it when its in. and id take the intake manifold of and check the push rods before you put it in
ratio411
3,870
73
109
Pensacola FL
Sep 28, 2007
  • Sep 28, 2007
You need a tranny compatible with the 390.
Depending on what the 289 had behind it, you may need driveshaft work.
The FE is alot heavier too. The front end is going to go LOW.
What did the 390 come out of?
You may need specific exhaust manifolds or headers (you may already have planned that route...).
p0prcksandc0ke
111
sacramento,ca
Sep 28, 2007
  • Sep 28, 2007
ya ull need a c6 tans if your going to put an automatic in
ratio411
3,870
73
109
Pensacola FL
Sep 29, 2007
  • Sep 29, 2007
Were Stang 390s available with FMX?
I am not real familiar with FE Stangs.
That may be a tranny option, and may be less work if your car was C4 originally.
Someone better versed in FE Stangs will have to confirm though.
p0prcksandc0ke
111
sacramento,ca
Sep 29, 2007
  • Sep 29, 2007
i have no idea all i know is i have a c6 with a 2 stage shift kit behind my 390
D
D.Hearne
11,730
south louisiana
Sep 29, 2007
  • Sep 29, 2007
He'll also need the big block transmission cross member. The FMX's also came with FE bells. I've got one hangin in my shop (anyone want it? ) Heads were specific to the Stangs, Fairlanes and Cougars, they had a different bolt pattern. Unless your heads are the 67-up castings, you cannot drill and tap the GT/CJ pattern into the heads. Headers are a must-- best ones are FPA's. Hooker's long tubes are a bitch in a big block Stang--- 3 hours just to install and tighten the bolts. Starter access is likewise a bitch. Ground clearance is also a PITA with Hookers. With the extra weight, you'll also need to beef up the suspension and unibody, the big block Stangs had different shock towers to handle the weight. Unless you have all the parts to do the swap, your best option is to go with a Cleveland or Stroker Windsor-------- big block power and everything bolts in place of a 289.
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
9
1994 Mustang GT 5.0 L Convertible
  • 94ns95
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2026
94ns95
9
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
