1968 289s
gt/cs
105
SW California
I was reading through this thread where there was a discussion re: the rareness of 289s in 1968 cars. I know that at some point in 1968 Ford started replacing the 289 with the 302, but I'm wondering when that was and how many of each were made.
My car's an original 289 (unfortunately the 289 it came with was long gone before I bought it), number 152044 out of the San Jose plant. Scheduled assembly date was March 22, 1968. Where is this on the timescale of 289 vs 302 production?
I used to own a '68 289 Sprint with a 289. The car was manufactured in July '68 and I was told it was one of the last before the switchover to 302s. Not sure how accurate the info was though :shrug:
Darren
The way I understand it is that they built them untill they ran out, and since they were building at 3 different plants, that time varied. I really think they ran almost all, if not all, production year. They used 302 blocks for the 289's when they ran out of the 289 blocks.
If the prior post is correct in stating that 289 production ceased in late July, how much longer was the model year anyway. A month?
I have sent an email to Kevin Marti , to see if he has the 68 302/289 production stats. If I get an difinitive answer, I'll post it.
Thanks for the great info guys. I'm a bit confused by this statement though:
Great68 said:
My car is on of those 302 block 289's.
I thought that the only difference between a 302 and a 289 was the crank and rods? Were the blocks cast differently, do they just have different casting numbers, or what?
It says "302" in the lifter galley of the block. That's about only difference I know.
My car was also a San Jose car, built February 21st, 1968
Just for kicks, I disassembled an original 302 from a 69 Galaxie, this was a plain jane 302-2bbl motor, nothing special about it. The owner didn't believe antifreeze was necessary here in south Louisiana, :rolleyes: sooooooo it had a large hole in one cylinder wall. And as I said before, there was nothing special about it :shrug: ......... till I removed the oil pan. Low and behold, it had those thick main caps.......... that told the story of how Ford liked to "use up" parts on the assembly line....... even the high performance stuff........... to build plain jane 302's using 289 Hi-po blocks :( :bang:
I thought that all the 302's in '68 were 4 barrelled and installed in GT cars? Anyway, my '68 was originally a 289 car. I've still got the engine at my parents house(it spun a bearing on a previous owner).
I didn't think there was anything special about '68 289's in Mustangs except for the larger combution chambers which decreased compression(not a good thing).
Randall
Randall
my 302 is a 2 barrel.
Yeah, but you said you had a Fairlane. In the '68 Mustangs, 302 engines were 4 barrelled.
edit: I reread my first post and see I wasn't too clear that I was talking about Mustangs. Sorry for the confusion.
Wouldn't there have been a vin change for 289 2bbl vs 302 2bbl?
In '69, when the 302 2v was standard you had the F code.
'68 was still using C code (which was a 289 2v). If I am not mistaken, wasn't the fairlane 302 2v an F code? I just can't see Ford not differentiating between the 289 2v and the 302 2v when they did so later.
A J coded vin was a 302 4bbl
Does anyone have an F coded 68 mustang?
It is possible that the confusion comes from the 289 4v to the 302 4v production. (Early 68's could have the A code 289 before the 302 hit full production)
