Ok well here it is for sale..I got a guy already comin to look and someone on here interested..but heres all the info and pics....
69 fastback
Its basically is completely stripped and needs floors. The body has all the bodywork done (professionally) and cost me $2500. They replaced the entire roof due to a crappy mid 70's sunroof. Trunk is pretty solid but the floors need to be replaced. They are basically cut out (but will need to be trimmed for the new pans). It comes with 3 fenders, both rear caps, a set of misc wheels and tires, 8" from a 66 (or for $500 more, I will include a 8.8 from a 02gt with about 13k miles on it. I will need the ears cut off and perches welded on but width is perfect). Doors are there, one door skin is cut off and I have the skin to fit on it. 2 hoods are included. Has a backglass and its in pretty good shape but will need a windshield and side glass (prefferably 70 bolt in). Comes with the lower dash, standard gauge cluster, couple sets of 69/70 seats. It will come with a stock 69 disc setup but will need to be cleaned and rebuilt along with a 69/70 power steering setup.
Some options that could go with the car if you are interested:
Upper and lwer control arms with Eibach progressive rate springs and KYB shocks
Built 9" with Richmond 3.89 gears and Auburn limited slip
396 stroker (69 351w block) dyno'd at 445.8hp and 500.1 tq...
Carb fuel system (Holley black pump, AN fuel line, Holley 750DP)
Fuel cell and mounting plate
I got a lot of different things for 69-70 stangs
Here are the pics from how it sits as of now to how we got the car when we bought it.
edit/////Price usually helps.... Asking $5000
69 fastback
