F folson Member Jun 6, 2018 35 0 6 IL Jun 6, 2018 #1 Jun 6, 2018 #1 New to the forum.. Hope to be here for awhile Any ideas on a C-4 trans that is leaking? any ideas where the most common leaks are? Also read that if the leak cannot be found if it only leaks a few quarts a year leave it alone?
horse sence 15 Year Member Nov 29, 1999 12,421 8,368 233 Wile Coyote's stunt double Jun 6, 2018 #2 Jun 6, 2018 #2 They tend to leak at the front seal ,the rear seal ,the shift linkage seal and oil pan gasket .Check the pan bolts ,they may be loose
F folson Member Jun 6, 2018 35 0 6 IL Jun 7, 2018 #3 Jun 7, 2018 #3 Thanks so much for the quick reply I will get back to you once I get back under the car....
