I have some left over Celebrex from shoulder surgery...Now if you look at the post where I said we about had the hood done, that was around 10PM, so, maybe a couple, six or seven hours. But, granted, it was way better than what I thought it was going to be after all your towel throwing. I was even under the impression coming out that I might not even paint it though. You do better work than you were thinking. I'm just sayin that you might be as anal as I am.
The party? I did. Even without smoking a doobie with the hippy fella.
I do think the water problem could be traced to the dirty inlet air filter. The compressor was having to run non stop, increasing the heat more than comes from just compressing air (which is considerable). The humidity in Alabama is pretty stifling in the first place, then increasing the temp of the air I was spraying wasn't allowing the water in the air to condense and be trapped by your water trap. It would finally cool running through that fifty foot hose and slowly build up enough to spit once in awhile. As is the case with both of us, the little sht causes pita problems. Bright side, you can just pick up a new filter while you're getting that switch!
The last point. Good picture Mike. I really did have fun. I need to admit I bought and took 1200mg's of ibuprofen at the airport, my back seems to be aching for some reason. We worked hard this weekend. If your hippy friend would just show up again, I think I might take a smoke break!
Sent from my iPhone using Tapatalk
