I use a piece of flattened copper pipe to back up holes I’m trying to weld closed. Sometimes it helps and of course if it’s a blind hole...
The hood scoop would cover inlet holes that wouldn't be expected to allow any cool air into it ( I agree, it's too low, and too far back) the purpose of the holes is to allow heat to escape while sitting in traffic. ( when under hood temps tend to skyrocket)A little food for thought.
if you are attempting to push cool air into the engine compartment with that little scoop it ain't gonna do much more than look cool. it would likely need to be about 4" high or higher to even catch some air off the hood that far back. Besides that the air entering the grill in front will cause more pressure in there rendering the scoop useless, pretty but mostly useless.
if you are attempting to move hot air out of the engine compartment facing the opening rearward would do more good but personally I don't like that.
To get more air into the engine compartment you have to get air out of there, as we know most air exits under the car. You may already have this, I don't remember, covering the area underneath between the bumper and the front area of the engine forces air through the radiator, around the engine and out under the car. If I remember right you cut openings at the back of the hood that will could let air out but would need to be bigger.
Just the ramblings of a madman.
And the effects of too much coffee.
May I remind you that Nik used an '83-'84 GT hood scoop. Therefore........I AM coolThe hood scoop would cover inlet holes that wouldn't be expected to allow any cool air into it ( I agree, it's too low, and too far back) the purpose of the holes is to allow heat to escape while sitting in traffic. ( when under hood temps tend to skyrocket)
The holes in the back of the hood would serve the same purpose. And on that note......
A while back @NIKwoaC did a really great job putting grilles on top of his hood, or hood scoop. I could care less that water could potentially get into this area if I was on the road and got trapped in a rainstorm,..I've always had a solution planned for that inevitability. ( I'm gonna cut up a magnetic backed sign, and stick it to the backside of the openings should that ever happen)
I know it won't be watertight, but it should slow water infiltration down significantly.....besides..I would just pull over in a deluge..the wipers on the monster are only slightly better than the ones that came on the model A.
That said..What about a nicely framed pair of flat grilled openings using nice hardware like Nik used? No scoop, just two heat exchanging grille openings maybe 4 X 12-18"?
Couldn't help but think...Well, Drew, you were on to it.
That old 1977 turbo Pinto TO4 was Henium coated.
You need to Protect Your Dave Hood Paint with a triple shot of Henium Coat (cf. Heany Industries ).
Tiles or bonding it, coat the underhood with space shuttle tiles, and have a Air Brake to create a Cowl Induction hood.
Opps, forgot to "Type R". BAKE=BRAKE
And CMA, you could just air brush the stuff on the hood. Everyone knows its not the:-
Custom Cool Air Gila heat exchangers
Custom Meth Injected,
Custom roller cam,
Custom aluminum Honda Ford II X flow head,
Custom 6 BBL ITB intake,
Custom EDIS and MegaJolt,
Custom MegaSquirt,
Custom Pistons and forged rods
Custom oiling system
Custom liners with
Custom converted side plate and
Custom 4 stage with Lockup clutch and
Custom narrowed 8.8" axle that makes your
Custom Wide 315 tired ride so tire fyring fast.
(Enough C's to carbon date C14...)
Honda guys know this all.
Ford taught em in 69-70. It's the Cyclone Spoiler Decal package. Stickers, my man.
Worth 450 flywheel hp over a stock 99 hp net 250 Maverick six everytime.
Let others Eat your Mercury's dust.
New avatar. Mercury Mission
I'll use the flame icon if you say whaaaaaat again. And then just regurgiate. My doctor says he can't help really sick people who say the same batsh!+ stuff over again with just anothe flame icon, but he's wrong. Spending 50 dollars an hour was wrong, I sware.![]()
Preperation H might be my next ℞
Anyway, happy assover, and Don't get Nailed....
Darn, forgot the p. Turned the sacred into the ignoble again.
Mind you P's and Q's, but especially your RRRRrrrrr's.
I don't get the correlation...how does the vents Nik put on his 83-84 scoop make you any cooler?May I remind you that Nik used an '83-'84 GT hood scoop. Therefore........I AM cool![]()
Wouldn't the speed "bake" part be lower? More behind the big black things hanging off the ass end of the shuttle?
I Don’t think the average stoner would make it past the index.In light of it being 420 day, I think getting baked would help one understand all 481 pages of the thread.
Now see Raggedy,..there's where I have to call you out..‘Cause the spoiler looks tiny and the hood scoop don’t fit
Fwiw-I liked the ductail spoiler, the vented hood I thought was a win-and secretly I was hoping the Thunderbolt-esque teardrop scoop from a few cars ago might make a return![]()
