• Sponsors(?)
CarMichael Angelo
clearly, I’ve got something going on in that hole
SN Certified Technician
14,180
234
62
Birmingham, al
m.imdb.com
For those who don’t ignore me...
BC cams wouldn’t let the excessive valve clearance slide. I was able to move shims around and almost get the intake cam completely gapped properly. But that left the exhaust cam needing almost every valve reshimmed....at 8.50 a shim.
So,...12 shims on the exhaust, and two on the intake plus a 10% slop factor in case I got one size wrong one way or the other added another 140.00 to this cam swap.
The converters gone,...on it’s way to Muscle Shoals for adaptation...that’ll probably be another 300-400.00.
In the grand scheme, it is what it is,...I’ve looked in on the guy’s thread whose trying to figure out a budget friendly Coyote swap, and he is every bit as expensive as where I am, before he even starts turning a wrench.
So, I’m in a much better mindset now that I know that I haven’t dumped anymore money in this thing than it would’ve been with something else.
droopie85gt
Hookers and Beer for life!
Dec 26, 2016
1,243
871
143
Cordova, TN
Nope. The only thing cheaper is an LS swap. And even with that, when you get down to it, the little things will nickle and dime you to death. Evidenced many times in this thread alone. Shims, fittings, gaskets, wire, wire loom, shrink wrap, etc. For those that say, by now you could have gotten a Barra at this price....there's still all the little stuff. Plus, on a used engine, I'd want to dingle ball, rings, bearings, gaskets, at a minimum. So you're still jacking up the price.
You'd think going 2.3 would be cheaper since it's only got one cam and 4 pistons. Nope, that :poo: is getting really obscure now.
I'm glad I'm 50 and not 30. In 10-20 years, they'll burn your house for having a gasoline powered car. If there's still any gasoline to be found.
  • Agree
Reactions: dr. Dan W.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,439
2,871
234
74
Dublin GA
lowendmac.com
Well, I must be a 74 year old museum piece driving 31year on antique car as a daily driver. I don't know if I could afford a battery pack for a 225 HP electric car...
CarMichael Angelo
14,180
234
62
Birmingham, al
m.imdb.com
I have my $140.00 pile of metal discs that will allow me to properly clearance the cams.
But..
Last week, While talking to Brian Crower, and after telling him how that fck that redid the head ground the valve tips in an attempt to “save me“ from having to buy shims to clearance the cams,....BC’s concerns were that dumbmthfcker ground through the hardening on the valve tips, and potentially exposed the now soft valve tip to “ mushrooming” through normal use. Potentially fcking up the entire top end of the engine.
Let me ask this of those of you that don’t ignore this thread.....
Is this concern gonna fuel a possible conversation with the 3AMD?
I’m drinking presently in an attempt to bludgeon the bitch ( the 3AMD) into a state of semi-consciousness, hoping he’ ll stagger off to some park bench,...wrap himself in some newspaper,... sleep it off,.....and leave me alone tonight.
It won’t happen....Alcohol is a stimulant...I’ll be mentally pulling the head by 3:15 am.
Nawww... I’m just kidding....I am NOT pulling that head, regardless of what the pos 3AMD thinks.
* until I start having excessive valve train noise after I get it running again.
And....in other news..
According to the email confirmation, my converter arrived at PTC today at 11AM. I figure I’ll give them a couple of days before I’ll call and ask them if they’ve opened the box. Aside from the obvious modifications to fit, I told them I was concerned that the smaller engine might need the converter tweaked to allow it to stall higher....so it might do more.....than fall out of a tree.
Reactions: RaggedGT
Admin Dude
Jan 4, 1985
28,947
10,928
224
Box behind Walmart
www.stangnet.com
You need weed dude. You and that ole devil can sit eye to eye and have this out long before 3AM.
jrichker
Mar 10, 2000
27,439
2,871
234
74
Dublin GA
lowendmac.com
But..
"However, the depth of hardening is ultimately limited by the inability of carbon to diffuse deeply into solid steel, and a typical depth of surface hardening with this method is up to 1.5 mm."
See https://en.wikipedia.org/wiki/Case-...epth of hardening,in a carbon-rich atmosphere. for more information.
LILCBRA
2,094
1,135
164
48
Marietta, Ga
Mike, way back when I worked in John Deere's engine works they had hardened caps for the valve tips, you could research that option. But then you may have problems shimming your valve train properly. Just a thought....
Sharing this link as an example:
Thread starter Similar threads Forum Replies Date
G flexplate needed for a 1978 mustang ii (5L V8) 1974 - 1978 Mustang II Talk & Tech 1
DIVER900 For Sale 1978 2.8L v6 power steering pump Mustang II Parts 0
G 1978 mustang ll motor mount 1974 - 1978 Mustang II Talk & Tech 2
A 1978 302 Serpentine conversion 1974 - 1978 Mustang II Talk & Tech 3
7 78 sport package ghia rarity 1974 - 1978 Mustang II Talk & Tech 12
L 1978 king cobra center wheel hub 1974 - 1978 Mustang II Talk & Tech 3
L 1978 wheel cap Cobra picture 1974 - 1978 Mustang II Talk & Tech 0
D Plug gap for 1978 302 in '67 Mustang? 1965 - 1973 Classic Mustangs -General/Talk- 6
R Headers for a 1978 Mach 1? 1974 - 1978 Mustang II Talk & Tech 5
K 1978 engine swap v6 to??? 1974 - 1978 Mustang II Talk & Tech 9
3 New Member: 1978 M II Mach I 1974 - 1978 Mustang II Talk & Tech 12
C 1978 MUSTANG II V6 Swap 1974 - 1978 Mustang II Talk & Tech 11
F 1978 rear end swap 1974 - 1978 Mustang II Talk & Tech 5
N Building a Daily Driver 1977 1978 V8 Auto 1974 - 1978 Mustang II Talk & Tech 4
colorado cobra Suspension 1978- Manual vs. Power Outer Tie Rods 1974 - 1978 Mustang II Talk & Tech 2
N 1978 Mustang Will a chevy 305 fit in it 1974 - 1978 Mustang II Talk & Tech 13
S Wheels-Tires 1978 5 lug disc brake upgrade and looking to fit 17 inch wheels 1974 - 1978 Mustang II Talk & Tech 0
colorado cobra Interior and Upholstery 1978 King Cobra missing radio delete panel 1974 - 1978 Mustang II Talk & Tech 6
Vic1978 Drivetrain 1978 Cobra Anyone Ever Install Performance Automatic Valve Body? 1974 - 1978 Mustang II Talk & Tech 4
colorado cobra Engine 1978 King Cobra Engine Seized From Sitting 25yrs. 1974 - 1978 Mustang II Talk & Tech 15
9 For Sale NOS 1978 King Cobra Wheel Mustang II Parts 6
D New Guys 1978 Coupe The Welcome Wagon 1
T trying to use 1979 clutch facing and pressure plate on 1978 flywheel 1974 - 1978 Mustang II Talk & Tech 17
Vic1978 1978 Cobra Vacuum Ported Switch Question 1974 - 1978 Mustang II Talk & Tech 3
Vic1978 1978 Cobra Smog Tube Help 1974 - 1978 Mustang II Talk & Tech 3
R For Sale Pair Of Tailights From 1978 King Cobra Mustang II Parts 0
Vic1978 Build Thread 1978 King Cobra Build 1974 - 1978 Mustang II Talk & Tech 66
Vic1978 WTB/Trade 1978 Mustang 302 Headers Mustang II Parts 1
Vic1978 Found Need Dash Pad 1978 Cobra Mustang II Parts 3
Vic1978 WTB/Trade Need A Fan Shroud 1978 302 Mustang II Parts 1
Vic1978 1978 Cobra Engine Harness Routing Help 1974 - 1978 Mustang II Talk & Tech 6
78ttop For Sale 1978 Mustang Ii T-top Fastback For Sale Mustang II Parts 1
P 1978 302 Mustang Ii Clutch 1974 - 1978 Mustang II Talk & Tech 10
G Expired 1978 Mustang Ii Fastback For Sale Mustang II Parts 0
5 Cl Find 1978 Mustang Ii King Cobra - $3400 (pensacola) 1974 - 1978 Mustang II Talk & Tech 0
V 1978 Mustang Ii Smog Removal 1974 - 1978 Mustang II Talk & Tech 3
V Value Of 1978 King Cobra 1974 - 1978 Mustang II Talk & Tech 4
rusty428cj Build Thread 1978 Mustang I I 1974 - 1978 Mustang II Talk & Tech 128
W For Sale 1978 Cobra Mustang Ii, 4 Speed 302. Grand Rapids, Michigan Mustang II Parts 4
M Expired 1976-1978 Lincoln Versailes Disc Brake Rearend For Early Mustang Swap Drivetrain Parts 1
kcobra302 Expired 1978 king cobra Other Classifieds 0
Jordan Carry 1978 King Cobra Mustang II restoration 1974 - 1978 Mustang II Talk & Tech 6
L Free Parts From My 1978 Coupe 1974 - 1978 Mustang II Talk & Tech 0
7 1978 Ford Mustang II T-Tops for sale Mustang II Parts 1
B 5.0 into 1978 Mustang Help 1974 - 1978 Mustang II Talk & Tech 3
D V-8 Mach 1 1978 parts for conversions Mustang II Parts 0
K Looking for my father's '65 convertible, sold in 1978 1965 - 1973 Classic Mustangs -General/Talk- 3
Bmwz389 1978 Mustang II Coupe for sale Mustang II Parts 2
Bmwz389 1978 4 Cyl Hard to Stay Running. 1974 - 1978 Mustang II Talk & Tech 3
F Need Bellhousing for 1978 Mustang II w/302 and c-4 trans. Mustang II Parts 1
