Just giving you the same reason to ignore the same threads I do..
Trust you/me. I ignore [lots] of threads
YOU CAN DO THAT?!?!Trust you/me. I ignore [lots] of threads
For those who don’t ignore me...
BC cams wouldn’t let the excessive valve clearance slide. I was able to move shims around and almost get the intake cam completely gapped properly. But that left the exhaust cam needing almost every valve reshimmed....at 8.50 a shim.
So,...12 shims on the exhaust, and two on the intake plus a 10% slop factor in case I got one size wrong one way or the other added another 140.00 to this cam swap.
The converters gone,...on it’s way to Muscle Shoals for adaptation...that’ll probably be another 300-400.00.
In the grand scheme, it is what it is,...I’ve looked in on the guy’s thread whose trying to figure out a budget friendly Coyote swap, and he is every bit as expensive as where I am, before he even starts turning a wrench.
So, I’m in a much better mindset now that I know that I haven’t dumped anymore money in this thing than it would’ve been with something else.
Well, I must be a 74 year old museum piece driving 31year on antique car as a daily driver. I don't know if I could afford a battery pack for a 225 HP electric car...I'm glad I'm 50 and not 30. In 10-20 years, they'll burn your house for having a gasoline powered car. If there's still any gasoline to be found.
Nice. I have a few things I've always wanted to try.
Unicorn tears are 113 octane
Are you all through?
Last week, While talking to Brian Crower, and after telling him how that fck that redid the head ground the valve tips in an attempt to “save me“ from having to buy shims to clearance the cams,....BC’s concerns were that dumbmthfcker ground through the hardening on the valve tips, and potentially exposed the now soft valve tip to “ mushrooming” through normal use. Potentially fcking up the entire top end of the engine.
It won’t happen....Alcohol is a stimulant...I’ll be mentally pulling the head by 3:15 am
"However, the depth of hardening is ultimately limited by the inability of carbon to diffuse deeply into solid steel, and a typical depth of surface hardening with this method is up to 1.5 mm."I have my $140.00 pile of metal discs that will allow me to properly clearance the cams.
But..
Let me ask this of those of you that don’t ignore this thread.....
Is this concern gonna fuel a possible conversation with the 3AMD?
I’m drinking presently in an attempt to bludgeon the bitch ( the 3AMD) into a state of semi-consciousness, hoping he’ ll stagger off to some park bench,...wrap himself in some newspaper,... sleep it off,.....and leave me alone tonight.
It won’t happen....Alcohol is a stimulant...I’ll be mentally pulling the head by 3:15 am.
Nawww... I’m just kidding....I am NOT pulling that head, regardless of what the pos 3AMD thinks.
* until I start having excessive valve train noise after I get it running again.
And....in other news..
According to the email confirmation, my converter arrived at PTC today at 11AM. I figure I’ll give them a couple of days before I’ll call and ask them if they’ve opened the box. Aside from the obvious modifications to fit, I told them I was concerned that the smaller engine might need the converter tweaked to allow it to stall higher....so it might do more.....than fall out of a tree.
You need weed dude. You and that ole devil can sit eye to eye and have this out long before 3AM.
