86 mclaren capri 5.0 5spd
I followed the checklist it will not run it barely will idle at 50 rpm dies
If you rev motor it breaks up bad will not go past 2k rpm
New computer,had a good extra upper intake replaced vacuum lines
No codes iac is new nothing is working
The only way it runs if you pull vacuum to bap sensor (speed density)
Then it idles and revs fine but I think it runs rich with bap vacuum wide open leak.
The converter glows.
Checked injectors all good
Changing the 02s will likely not help but get some new ones anyway, your gonna need them when you get it running right.
not sure what that means?
