1987 5.0ho to old c4
twuxtop
50
not 65 c4 but the next newer. im told i need a different torque converter and bellhousing to fit the flywheel to my c4. i also need a thinner fan or outside electric fan, where can i get these for cheap?! thanks in advance
Did the 5.0 donor car have an AOD? Either way you need a new flywheel and TC as has been said, possibly a new block plate and starter too.
New electric fans are not cheap, if you do find one cheap there's probably a reason for it. However the junkyards are literally full of them, I'd buy a salvaged electric fan before spending a dime to make the mechanical one fit.
If you have the newer style C4 and a post 1980 302 then you will need the 164 tooth 50 oz. One from the AOD 302 will work. If you have a Pre 1980 then get the AOD 351.
Here is a chart. The Flat and Dish is how they looked to me as they related to the crank.
ALL EARLY LATE ALL
ENGINE 300 302 302 351W
WEIGHT IN OUNCES 0 oz 28 oz 50 oz 28 oz
YEAR
C4 PRE 1977 157 dish 157 dish 157 dish 157 dish
C4 1977-up 164 dish 164 dish 164 dish 164 dish
C5 164 dish 164 dish 164 dish 164 dish
C6 164 flat 164 flat 164 flat 164 flat
FMX 164 dish 164 dish 164 dish 164 dish
E4OD 164 flat 164 flat 164 flat 164 flat
AOD 164 dish 164 dish 164 dish 164 dish
Ford Part Numbers:
D5TZ-6375A 164 flat 0 oz
C5TZ-6375T 164 dish 0 oz
C3AZ-6375L 157 dish 28 oz
EOAZ-6375A 164 dish 28 oz
D1ZZ-6375A 164 flat 28 oz
E1TZ-6375C 164 flat 50 oz
E2AZ-6375A 164 dish 50 oz
E3TZ-6375G 164 dish ?
