1989 5.0 Gas mileage
revedup
63
S.F. Cal,
Hello got an 89 5.0 original o2 sensors exhaust about 100,000 miles cars bone stock with 211.000 miles exceprt has a K and N air filter.
A 5 speed.
Mileage seems to be lately about down to 11.9 mpg semi freeway.
If the 02 sensors were changed would it help?
Car semi dies on start up from cold at idle.
Always has passed smog test .
A california car.
No a.c.
Give all your ideas please. thanx:D
273 to 1 rearend ratio :D
it's an L.X. 5.0
You should get considerably better mileage than that. Mine gets 19 in town and 23 on the highway with the A/C on. Can't remember if the 89 has a check engine light or not but if the O2 sensors are bad then changing them would help the mileage some. Try cleaning you IAC, check your plugs, maybe new cap, rotor, wires. Check your timing.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Ive got an 89 engine/drivetrain in my 93 coupe, its a 5spd and I just got back from a trip yesterday evening and I got 24.5 mpg and I have 3.08 gears. The engine has 192k miles on it.
Do pull the codes, thats the best thing to do to see exactly what is going on with your car. It might be a little intimidating at first but its really not that hard to do.
i get around 23-25 on the highway, not sure in town. 2.73 gears and a few mods. i would def. tune it up and change the o2's. see where that gets ya.
