Up for a sale, a nice 89 Mustang Lx 5.0 with 5speed man trans.
Car in excellent condition for its age.
Asking $8500 or best offer.
Serious inquires only.
Email @ [email protected] for more pics and any questions about the car
General Specs.
1989 Ford Mustang LX with 5.0 V8 25th Anniversary
5.0 Liter V8, dyno @ 293 bhp with 395 ft/lbs of torque.
5 Speed Manual Transmisson
Black with Grey Cloth interior
GT Sport Seats w/ power lumbar support
85,675 original miles
Cruise control
Sony AM/FM CD Radio with 12 disc Changer
MB Quart component Speakers Front, Infinity Component Speakers Rear
Autometer Fuel and Tachometer in A-pilar Guage Pod by Autometer.
Original Ford floor mats.
New Headliner w/ abs board, will never need replacement
Removable pop up Sunroof w/ original storage bag.
APC Headlight w/ built in Fog lamp, and GT headlight/Fog light Switch.
Running Pony rear emblem
Centerforce Gold Clutch changed at 75K miles, new adj. cable.
Exterior Modifications:
No body mods, all original.
Kenny Brown jacking rails, subframe connectors with X brace.
Engine
Stock Block with no bottom end changes.
Stock intake with K&N panel filter (new)
Pro M 75 mm Mass Air Flow sensor (chrome)
65 mm FMS throttle body
FMS GT40 Intake upper and Lower- Both extrude honed for even flow between cylinders
Edelbrock aluminum 5.0 rpm Heads (save almost 100 lbs off the front end)
FMS aluminum Cobra 1.6 Roller rockers arms
Manley pushrods
FMS Aluminum radiator with- new hoses
Magnecor 8.8 mm red ignition wires
rear main oil seal replaced @ 80K miles
Energy suspension polyurethane bushings- engine/ trans mount, lower control arms etc.
FMS Cobra ECU
24# lb fuel injectors with adj fuel pressure regulator, 190lph fuel pump Fms
New oil pump and with
Full Fel-pro engine gasket set
New FMS water pump
130 amp PA alternator
FMS hydraulic lifters
comp cams custom grind cam, full emissions legal.
FMS harmonic balancer
Ford Motorsport Ceramic coated shorty headers with Stage 8 locking bolts
Catco free flowing catalytic h-pipe
Flowmaster force 2 -- 2 1/2 in cat back exhaust w/ stainless steel tips.
Saleen Racecraft Specific rate Springs
Koni Red adjustable front Struts/ Rear Shocks and rear horizontal shocks.
Maximum Motorsports rear lower control arms
Baer Racing 13in Track kit, 5 lug conversation with Strange 28 spline rear axles, cobra master cylinder with wilwood adj. proportioning valve.
front and rear stainless steel brake lines
13in Rotors Front with twin piston calipers, 12in rear with single piston calipers and parking brake.
17 in Ford 1999 Cobra wheels w/ P245 40 ZR17 Yokohama AVS intermediate Tires- only 5000 miles on them.
Saleen front and rear sway bars.
BBK camber plates adjustable
