I'm getting desperate at this point.
So, I had bad compression in two of my cylinders and my car drank coolant before I started this job nearly two months ago, so figured I would check the head gaskets. I have never had this engine open since I got the car. At the same time, I pulled some GT40p heads from the junkyard, had them surfaced, cut, and checked for cracks and put them on the car with an early explorer upper and lower intake as well. I got good gaskets and put everything back together with the right torques and, to my knowledge, in the correct orientation.
Today, I tried to start the car for the first time and it was great for the first couple minutes of idling. There was some smoke coming from the tail pipes, but it wasn't too serious. I was filling up the coolant slowly as it drank it from the radiator. However, after a few minutes of idling and occasionally raising the rpm to around 2k, more and more smoke started pouring out the back. Within a few minutes as the engine got hot, it was dumping huge clouds of white smoke out of the pipes. I hoped that it was just the extra crap burning out of the pipes, but it was seriously thick smoke.
After a few more minutes, it explosively began to overheat. Coolant started boiling into the overflow container and actually managed to push vapor past the big c-clamp on the lower radiator hose. Both the water pump and the thermostat are brand new. I stopped the car and vaporized coolant continued to boil out for many more minutes.
I'm absurdly frustrated with this whole thing and I really want to see if there is anything I can do before taking this whole thing apart AGAIN. Did I install something wrong? I put the head gaskets on with the "front" facing the front, so I know I'm not blocking the wrong water jackets. If I dinged up the head gaskets while installing them, could that be a cause? I'm going to do a compression check as soon as I get home and I'll post the results. Until then, is there anything else that could be causing this? I'm ready to bash the car to pieces with a wrench.
