Fuel 1990 installing edelBrock intake
  • Thread starter Thread starter Beaker
  • Start date Start date Oct 5, 2026
  • Tags Tags
    edelbrock flowtech head head swap intake vacuum lines
Beaker
Canada
Oct 5, 2026
  • Oct 5, 2026
Hey
I’m trying to install a edelBrock performer rpm 2 on my 1990. There are 3 threaded holes I’m lost on. 1 goes to pcv, 1 goes to firewall (I think ). And the last one, the instruction says tee off and go to fuel pressure regulator and map sensor. I can figure out the fuel but I’m lost on where this is
HELP
rednotch
I'd like to remain having one chocolate starfish
1,528
725
143
south jersey
Oct 5, 2026
  • Oct 5, 2026
Map or bap is the small black box on firewall, only gets vaccum on none mass air cars..
Beaker
Canada
Oct 5, 2026
  • Oct 5, 2026
Ok thanks. Kinda new to this. So if I have a maf sensor in my air intake, this means i have mass air and shouldn’t need vacuum?
Thanks
AeroCoupe
6,243
4,334
183
Claremore, OK
Oct 6, 2026
  • Oct 6, 2026
That is correct. I will tell you that with a stock motor you will loose some bottom end power with the RPM II upper. I have this upper but its on a built 331 and it starts to build real power at about 3,000 rpm with my motor. Hopefully you got a good deal on it and are shooting to grow into the intake.
rednotch
1,528
725
143
south jersey
Oct 6, 2026
  • Oct 6, 2026
Thanks
Yes on mass air cars its a BAP sensor and reads atmosphere pressure so no vaccum gets connected to it.
Beaker
Canada
Oct 6, 2026
  • Oct 6, 2026
AeroCoupe said:
That is correct. I will tell you that with a stock motor you will loose some bottom end power with the RPM II upper. I have this upper but it’s on a built 331 and it starts to build real power at about 3,000 rpm with my motor. Hopefully you got a good deal on it and are shooting to grow into the intake.beauty
rednotch said:
Yes on mass air cars it’s a BAP sensor and reads atmosphere pressure so no vaccum gets connect
Beaker
Canada
Oct 6, 2026
  • Oct 6, 2026
Beauty. Thanks. Yes it just got a fresh edelBrock intake and Florence heads with a Trickflow cam. Just waiting for throttle body. After that, I have a brand new vortech sitting on the flow waiting its turn
Reactions: DadLife0724, Potomus Pete and General karthief
AeroCoupe
6,243
4,334
183
Claremore, OK
Oct 6, 2026
  • Oct 6, 2026
Well well well…I see you were holding out on us. Now a build thread will be needed with lots of pictures please.
Reactions: LILCBRA and DadLife0724
Admin Dude
Jan 4, 1985
43,565
21,736
234
Box behind Walmart
Oct 6, 2026
  • Oct 6, 2026
That should help.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
  • dan50
  • Jul 18, 2026
dan50
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
