Expired 1991 Mustang 5.0 Lx Auto - All Original $7,500 Obo
Mustang LS (Ingomar).webp Mustang LF (Ingomar).webp Mustang Front (Ingomar).webp Mustang RF (Ingomar).webp Mustang RR (Ingomar).webp Mustang Rear (Ingomar).webp Mustang Drivers side (Ingomar).webp Mustang Drivers seat (Ingomar).webp Mustang Rear Seat - from L (Ingomar).webp Mustang Window Sticker (smaller).webp
This is an impeccably maintained, all original 1991 Mustang LX 5.0L Hatchback. Auto Trans; Oxford White exterior with Titanium Cloth/Vinyl interior; and just over 108,000 pampered miles.
This Mustang was purchased new by my mother and owned and gently driven by her until she passed away two years ago. She always kept it garaged or covered. It is all original and in excellent condition inside and out. There are only three cosmetic flaws: a nickel size ding just above the bottom of the right door; and two cracks (3" and 1" long) in the LR taillight lens.
Its condition alone would more than justify the asking price, but when you look at the Features and Extras that are included it’s a bargain:
FEATURES
● 5.0L V8
● AUTOMATIC TRANS
● AIR CONDITIONING
● CRUISE CONTROL
● POWER STEERING & BRAKES
● POWER WINDOWS, LOCKS, & SIDE MIRRORS
● ORIGINAL 16 INCH 5 SPOKE CAST ALUMINUM WHEELS
● CARGO COVER & NET
● AM/FM CASSETTE W/ 6 SPEAKERS & AUX INPUT
● PROTECTOR ALARM W/ REMOTES FOR DOOR LOCKS & HATCH
● ARTICULATED FRONT SEATS WITH POWER LUMBAR SUPPORTS
● REAR WINDOW DEFROSTER
You can review more details in the accompanying window sticker.
EXTRAS
● New Front Brakes, Hubs, Bearings, & Seals
● Recent Tune-up
● Recently refreshed steering linkage
● Only 12K mi. on Continental Extreme Contact DWS Tires
● Amsoil synthetic oil since break-in (+ 2 new Amsoil filters)
● Complete Maintenance Records
● Full Set of Factory Manuals (including: Service; EVTM; Specifications Book; and Wiring Diagrams)
● Original Window Sticker & Purchase Docs
● Smart Mat Cargo System with Collapsible Bin
● Aux input (3.5mm plug) for original radio hidden in cubby below
● Covercraft Ultralon Cover with cable, lock, and carrying bag
● Two: one pound cans of Freon (R12).
I hate parting with this Mustang, not only for sentimental reasons, but because it’s a fun performance car and a real show stopper, equally adept at errands around town or long highway trips. Plus it’s incredibly reliable, in excellent condition, and comfortably fits my 6 ft. plus frame. But I have too many vehicles as it is, so it has to go.
Please respond to my post for more details or to schedule a visit. I'm located in Eureka, CA, which is about half way between San Francisco and Portland, OR. I'm planning a shopping trip to San Francisco soon (and maybe even to SoCal), so hooking-up there may be possible if you'd like to look the car over.
$7,500 OBO; CASH ONLY, NO TRADES
DAMN IT - Somebody buy this thing and give it a good home so I will stop obsessing over it. SD WItmess - you take payments? Trade ya my 90 EB Bronco and give you my kidney when I die :)
VEHICLE ISSUES
Regarding needed repairs, there are none that I know of (and I should know since I’ve been maintaining the vehicle for the past 20 years) needed to fully enjoy this Mustang. It’s in that good of a condition. However, there are about ten issues (four functional and six cosmetic), all of which I would call minor or even trivial, which could be addressed when convenient and would make this Mustang functionally and cosmetically identical to when it left the dealer’s lot. Specifically:
FUNCTIONAL ISSUES:
Console lid latch:
-There is a latch for the center console (cubby) lid to lock it in place. The latch is fine but the plastic plate it engages on the underside of the lid is broken off. The simplest and most durable fix would be to screw a small aluminum plate in place of the missing plastic (since it’s on the underside of the lid no one will see it). I’ve never bothered to fix it since I prefer it as it is. For me, it’s far more convenient to simply flip open the lid without having to release the latch. The lid doesn’t flap or bounce, even over hard bumps, so I don’t regard the latch as necessary, just an impediment.​
Driver’s visor vanity lamp switch:
-Each visor has a lighted vanity mirror. I was checking all of the light bulbs on the vehicle yesterday and noticed that the lights for the driver’s side vanity mirror would only turn on when the actuating button for the switch was manually extended to its limit or moved to the side. These switches seem to be a common problem judging by online forums.​
-Repairing the switch itself should be easy. However, accessing it is problematic: the plastic frame holding it, the lights, and the mirror to the visor would have to be removed, a procedure not intended by the factory. It appears from some forum entries that the frame is held in by plastic pins pressed into the visor backing. They can be pried out but it is a delicate procedure and can break the pins.​
-Because of the risk of damaging the frame in the process of repairing the switch, and the fact that I never use the vanity mirror anyway, I’ve never attempted the repair.​
Coolant weeping at engine front cover:
-The engine front cover (timing chain cover) on 5.0L and 5.8L Ford engines is sandwiched between the water pump and engine block. For simplicity, the screws holding the water pump to the front cover run through the front cover and thread into the engine block. As a consequence, if the water pump is replaced, disturbing those screws can disrupt the seal between the front cover and engine block, resulting in a very slight coolant leak that pools in a crevice at the top of the front cover. This is a common problem as I found on my ’94 5.8L Lightning after replacing its water pump.​
-Not quite three years ago the water pump on this Mustang was replaced. Naturally, this created a slight coolant leak at the top of the front cover between it and the engine block. I’ve tightened the front cover/water pump screws about 10% above the maximum recommended torque and, as a result, the leak has been reduced to a very slight weeping, which I believe is acceptable.​
-To reseal the front cover to the engine block is not a trivial matter. It requires pulling the radiator, sectioning the oil pan gasket and replacing that section, and replacing the front crank seal, all for starters. Given the amount of labor required for that endeavor, I believe the slight weeping I’m currently experiencing is completely acceptable.​
Rear Window Defroster:
-I’m suspicious that one of the elements (traces) in the rear window defroster isn’t working. However, I haven’t had the opportunity to determine that for sure (I seldom leave the vehicle out overnight uncovered). If it is a broken trace there are kits that make repairing it relatively easy.​
COSMETIC ISSUES:
Cracked light lenses:
-The front left indicator lens and rear taillight lens have cracks in them. The cracks are barely visible and do not affect the functioning of the lights. I’ll post photos of them for your review.​
Spider cracks in windshield:
-There are two spider cracks in the front windshield, both are smaller than the size of a penny:
-One has already been repaired, so it is barely visible. It is about an inch to the right of the center of the windshield, which puts it out of the driver’s view ahead.
-The second is about six inches to the right of the rear view mirror mount to the windshield, so it’s hidden by the mirror in the view of most drivers. Since I can’t see it while I’m driving I haven’t bothered to have it repaired.​
Dings in passenger door:
-There are two very small defects at the bottom-rear of the passenger door:
-One is a small dent (smaller than a dime)
-The other is a barely perceptible crease, about 1-1/2 in. long.​
-Both have been reduced as much as possible (without repainting the lower door) and blended with touch-up paint so they are barely perceptible (see the accompanying photos).​
Deteriorated trim paint:
-Exterior mirrors:
-The black paint on the bottom and lower edges of both outside mirrors has worn off. Since the plastic underneath is also black the missing paint is hardly noticeable.
-I hope to repaint the mirrors prior to sale.​
-Drivers door handle:
-The paint on the driver’s door handle has faded and could stand re-finishing.
-I hope to re-finish the handle prior to sale.​
-Windshield wiper arms:
-Some of the flat black paint on the windshield wiper arms has worn off, so they could stand re-finishing.​
Scratches in cargo area:
-There is a line of scratches running along the plastic cladding at the rear of the cargo area.​
As you can appreciate, with only these few issues, most of which can be easily and inexpensively addressed, this Mustang is in excellent condition. With only a little work it could easily be upgraded to concurs condition and be competitive at car shows.
View media item 12503View media item 12504View media item 12505View media item 12506
