- Sep 1, 2015
- 2
- 0
- 13
Hello Up For Sale Is My 1991 Mustang Gt Over 25k Invested Between Me And Previous Owner With A Huge Folder Of Receipts.
Has Been Fully Restored. Car Was Stripped Completely. Painted White With Silver Lower By Fineline Auto In Kc. Interior Extremely Clean With Everything Working Including All New A/C Components. Blows Cold Still Running R-12.
Mods and additions (in no particular order whatsoever):
Engine And Transmission Have 2000 Miles On Them
Engine Bored 30 Over
FMS E-303 Cam
Trick Flow Aluminum 170 Degree Heads
Trick Flow Street Heat Upper And Lower Intake
42 Lb Injectors
BBK Equal Length Shorties
80 Mm Mass Air
Bbk 75 Mm Throttle Body And Egr Plate
8.4 to 1 Compression
Procharger 600b
8.5 Mm Ford Racing Wires
Autolite Double Platinum Plugs
Steeda Air Oil Separator
130 Amp Alternator
Battery Relocated To Trunk
Radiator With Dual 12 Inch Slim Line Fans
Aeromotive In Tank Fuel Pump
Has Been Tuned By Mc Racing With An Sct Chip
Fully Rebuilt C4 Transmission With 2500 Stall:
B&M Shifter With C-4 Conversion
373 Rear End Gears
Rear Disc Brake Conversion
Steeda Bump Steer Kit
Mishimoto 4 Core
Bbk Strut Tower Brace
Bbk Sub Frame Connectors
Eibach Springs
New Shocks Struts
Bbk Caster Camber Plates
Steel 2.5 Inch Cowl Hood
Saleen Wing
Cobra Grille Insert
Steeda Radiator Bracket
New Evaporator And Heater Core
Interior Was Completely Removed Including Dash Duct work Cleaned And Reassembled
Power Windows and Locks Are New And Work Properly
Has Pillar Gauges Boost Temp And Battery
Complete Alpine Sound System With Bluetooth
Amps Are Concealed In Original Spare Tire Location
3 Jl Audio 8 Inch Subs
I'm Sure I Have Forgotten Some Items but all the paperwork comes with the car.
I Am Asking A Reduced Price And A Fraction Of What's Invested The Driver Door Was Slightly Damaged At A Car Show This Last Weekend This Is Reflected In My Asking Price Of $8500.
Please Call Or Text Jamie If Interested (816)529-7299
The car is located in Independence Missouri.
FMS E-303 Cam
42 Lb Injectors
80 Mm Mass Air
Procharger 600b
130 Amp Alternator
373 Rear End Gears
Mishimoto 4 Core
Eibach Springs
New Shocks Struts
Saleen Wing
Cobra Grille Insert
