1992 Built & Blown coupe
tjmayer
NEW PICS BELOW BRAND NEW FULLY BUILT C4, NEW WHEELS, SEATS, EVERYTHING REDONE CAR NEEDS NOTHING.
have stock seats also.
Only reason I'am selling this car is i got a hell of a deal on another car i could not pass on but anyway having an aeromotive eliminator fuel system installed as we speak which cost me 2,300 but here is a run down also had all the trim redone around all the windows brand new c4 seats just waiting on drag radials.
I have a lot of the receipts from the build of this car and other documentation.
1992 Bimini Blue Mustang LX Coupe
121,000 Miles on body. Completely repainted with original color
Cervini's 2 1/2 Cowl hood
Convo pros with centers painted new tires.
Relocated battery
Gauge pod w/Tach and shiftlight, Oil and fuel pressure, boost/vac, coolant temp
Upgrades completed in the last 15,000 Miles:
306 LONGROD PRO BULLET LC/TW DSS Forged
Pro-Lite pistons, super strong forged 5.400" I-beam
rods with ARP rod bolts and micro-polished race
prepped crankshaft, balanced and blueprinted,
assembled in a race prepped 302 block with the
billet aluminum Main Support System installed
50oz SFI SBF balancer
Low profile 7qt oil pan with pickup includes baffled oil return hole
Comp Cams 276HR .544/.560
TFS Trickflow heads and intake
Vortech V1 S-trim currently pulleyed for 14lbs
AFM Power pipe with Bosch bypass
Bassani equal length headers Full length exhaust
MSD 6AL and MSD Coil
AFM PMS Series 3 w/3 bar MAP sensor Tuned by Mike Post
42# injectors
Abaco MAF
Black magic fan
Aluminum Radiator
Fully built C4 brand new
new clutches
new band
reinforced forward drum
hardened input shaft
manual valve body
deep pan
billet servo
TCI conv
cooler and lines
B&M shifter
Maximum Motorsports MMKMP-10 w/brand new Cobra Coupe Struts
Package Includes:
MM K-Member
MM Front Control arms
MM Front Coil-Over Conversion kit
MM Aluminum Steering Rack Bushings
MM Caster/Camber plates*
MM Adjustable Tie-Rod Ends
MM 2-Point K-Member Brace
Urethane front swaybar bushings
Swaybar end links (shorter)
MM Front Swaybar Relocation Kit
D&D Motorsport upper and lower control arms w/sperical bushings.
Included with the car, but currently not installed.
Most of the AC equipment, Possibly all of it
asking just for some of my money back 10,500 obo and thats with fuel system installed have dyno sheets any ? 515-669-7107.
