SOLD 1992 Mustang Gt 5spd. 62k
Gunsbee
92 Mustang 5Spd. GT Hatchback. Car has factory sunroof. 62K Miles. Pro 5.0 Shifter. Procharger D1 with 12 rib and 3 core intercooler upgrades. 6G One Wire 120 amp alternator. Uego 1000 Wideband gauge. Vortech Fuel Rails. Aeromotive Fuel pressure regulator. 42lb Injectors. 255LPH in tank pump and 255LPH in line pump. Corbeau fully adjustable 6 Point welded in roll cage and sub frame connectors. TRS grey cloth racing seats. 4 Point Pyrotect seat belts mounted to roll cage. Cobra R 17x9 rims. Aluminum 3 core radiator with flex a lite dual fans. Auto meter boost/vacuum, voltage, oil pressure, fuel pressure, and shift light. Anderson switch panel in ash tray controls gauge lights. Others unused. Trick flow track intake. Pro flow mass air meter. Professional products 75mm throttle body. Procharger D1 supercharger with 12 rib and 3 core intercooler upgrades. I have a 10,14, and 17 lb pulleys. Anderson PMS4 with custom tune. ARP head studs. Fel pro head and intake gaskets. Mac 1 5/8 Long tube headers. Mac Pro chamber mid pipe and mac mufflers all the way to rear. All 3 inch. Comp cams rocker arms. MSD 6A ignition. Heads were gone through and valve job at 55K miles. Custom stereo with 1 ten inch sub. Car has in between 450-500 wheel horsepower. Last time it was dynoed it had 433 and that was before the pms and tune. I have a full folder of receipts and can answer any questions you have. Only thing the car needs is new tires. Title in hand. Asking $10000 or best offer. Please contact me at 217 nine7one 5two17. Springfield IL.
