Fox 1993 FOX High Idle
  • Thread starter Thread starter TheJay806
  • Start date Start date Dec 24, 2024
First Prev 2 of 2
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Dec 31, 2024
#21
  • Dec 31, 2024
  • #21
I could not for the life of me remember. I have an image in my head of a seal but don't remember what it's from (Ford, Chevy, GM, other).
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Dec 31, 2024
#22
  • Dec 31, 2024
  • #22
I just stole this from another thread (funny how that works):
This is where your leak would be.
AeroCoupe
6,193
4,296
183
Claremore, OK
Dec 31, 2024
#23
  • Dec 31, 2024
  • #23
There is a seal on the TPS but it’s a moisture seal more than anything.
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,953
5,831
213
Jan 1, 2025
#24
  • Jan 1, 2025
  • #24
The egr usually wisps a little smoke at that orange seal duri g a smoke test. Not saying it isn't bad. The most common area for a vacuum leak is the hose that runs under the intake behind the distributor. That hose is hard to see and to get to. ( should be seen in a smoke test.
I seem to remember an o ring type seal under the factory tps. Its been a very lo g timesince I've seen one though. I know my aftermarket one doesn't have one on it...and hasn't for many years. A very small amount of snoke is acceptible from the throttle shaft wnen smoke testing.
Reactions: General karthief and AeroCoupe
T
TheJay806
21
DFW, Texas
Jan 4, 2025
#25
  • Jan 4, 2025
  • #25
Replaced the EGR valve and boom, idle immediately dropped down to normal. Problem solved. Thanks everyone. I did a smoke test one more time to double check and no leaks.
Reactions: General karthief, AeroCoupe and gkomo
T
TheJay806
21
DFW, Texas
Jan 8, 2025
#26
  • Jan 8, 2025
  • #26
Mustang5L5 said:
But stock TBs have the hole present, so hard to say if he’s looking at someone’s band-aid fix, or just a stock TB blade with a hole present.
Stoxk hole here
Any idea what size this hole is? Could i put a lock screw and bolt in here or is it to dangerous?
T
TheJay806
21
DFW, Texas
Jan 9, 2025
#27
  • Jan 9, 2025
  • #27
Stoxk hole here
Can I block or lock nut and bolt this hole? Or is it to risky and better off getting a new throttle body?
KRUISR
1,877
1,017
143
Jan 9, 2025
#28
  • Jan 9, 2025
  • #28
To test if blocking holes improves things, sure. Could do some JB Weld or some silicone at least to test it. If it works a more permanent solution can be figured out.
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Jan 9, 2025
#29
  • Jan 9, 2025
  • #29
There is nothing you need to do with that hole IMO. It's there from the Factree.
Reactions: Mcmahst and General karthief
Mustang5L5
Mod Dude
Feb 18, 2001
43,351
18,087
224
Massachusetts
Jan 9, 2025
#30
  • Jan 9, 2025
  • #30
The hole is not the issue. It’s supposed to be there. Blocking it may actually cause the throttle to stick slightly.
If you want to test it to see if it’s the cause of your issue, stick a nice peice of duct tape firmly across it. If the idle is still high your problem is still elsewhere
Reactions: TheJay806
T
TheJay806
21
DFW, Texas
Jan 14, 2025
#31
  • Jan 14, 2025
  • #31
I followed these instructions for resetting the idle etc. it worked like a charm. On start up it now idles at 750. After driving for a bit it moves back to 1000rpm. If I shut it off and start up a little later, back to 1000rpm. Is this normal? Or would this be a faulty IAC? I have a new IAC I can throw on and do the procedure again if need be?
Clear the computer's idle memory by disconnecting the battery for 20+ minutes.
-Disconnect the Idle Air Bypass solenoid (IAC)
-Reconnect battery
-Start engine and set idle speed to desired RPM with idle screw on throttle body
-Turn off engine and reconnect the air bypass solenoid
-Set TPS voltage between 0.90 - 0.95 volts with a digital volt meter
-Start engine and let it idle for 2 minutes with no accessories on.
-Turn off engine for two minutes
-Start engine again and run for 2 minutes with every accessory turned on.
-Turn engine off again.
KRUISR
1,877
1,017
143
Jan 14, 2025
#32
  • Jan 14, 2025
  • #32
The steps you did were pretty good, but you missed a key one near the beginning.
When you disconnect the IAC, you need to disconnect the SPOUT connector on the distributor as well. If you don't, the PCM will keep adjusting the timing to improve idle while you are making adjustments and you will be chasing your tail trying to get it lower.
Also, when you set the idle, set it as low as it will still keep running - it will not likely run smooth but it just needs to keep running. I have gotten the idle down in the 550 - 650 rpm range on this step. The lower you can get it, the more range the IAC has to work with to maintain idle when you are done with the process.
The rest of the steps you did looks good.
T
TheJay806
21
DFW, Texas
Jan 14, 2025
#33
  • Jan 14, 2025
  • #33
So the only way I could get it to work is by starting the car with the IAC already disconnected, can I do the same with the spout?
KRUISR
1,877
1,017
143
Jan 14, 2025
#34
  • Jan 14, 2025
  • #34
Yes. That is how you set the timing on our cars too - with the SPOUT disconnected, then starting.
T
TheJay806
21
DFW, Texas
Jan 15, 2025
#35
  • Jan 15, 2025
  • #35
I re did this procedue, removing the SPOUT this time. The idle again dropped down of course, I had the idle screw backed out and then adjusted to "set" the idle. Idled perfect. Then took it on the road, and at the light, idle sits at 1000rpm.
Mustang5L5
Mod Dude
Feb 18, 2001
43,351
18,087
224
Massachusetts
Jan 15, 2025
#36
  • Jan 15, 2025
  • #36
When it idles up, unplug the IAC.
What happens?
T
TheJay806
21
DFW, Texas
Jan 15, 2025
#37
  • Jan 15, 2025
  • #37
What happens?
I'll try again tonight, but typically before, If I unplugged the IAC while the engine was running it did nothing. No change. That was before actually getting the idle lower though. I've smoke tested and no vac leaks, EGR was leaking previously, I replaced it. EGR is installed and connected but hoses are capped off.
But, if i let it sit for while, and go back and restart it, it'll idle perfect again. It just seems like once I start driving, on the hwy especially, then the idles stays at 1000
Mustang5L5
Mod Dude
Feb 18, 2001
43,351
18,087
224
Massachusetts
Jan 15, 2025
#38
  • Jan 15, 2025
  • #38
can you provide additional info on the car? There are a few other things that would cause this depending on a few things.
What year is this car? Original mass air car? Have you dumped codes? Do you know if your VSS is hooked up? Is this an AOD-to-T5 swap car?
There are some electrical gremlins with swap cars with mismatched ECUs and stuff that can also cause idle hang.
First Prev 2 of 2
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
Idle issues….again.
  • Nostang25
  • Sep 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 7, 2025
AeroCoupe
