1993 GT automatic changed to 5spd - computer question
Will the stock automatic computer properly control the engine for high performance use since it has been changed over to a 5spd - car runs good but I wonder if it is to blame for the car feeling sluggish compared to my other A9L 1993 GT setup. I have heard that the A9P automatic computer can only be used in an automatic car even AFTER the car has been changed to a 5 speed due to neutral safety switch issues so it has me wondering - would a custom chip solve performance issues if there are any or is the A9P computer just as fast as an A9L and I need to work on other things to get it to feel less sluggish. Also -- chip or not to chip - that is the question.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Don 95Vert said:
The A9P is actually more aggressive in spark than the A9l - 26* vs. 30.8* for the A9P at WOT max RPMs.
30.8??? where did you find this info , my A9L throws about 21-22 degrees advance and my buddies A9P does throw more degrees timing in it but its about 25-26 degrees.....I have checked them both myself with a good timing light .....
Chalk up another AOD-to-T5 conversion with an AOD computer, here. No issues with mine (at least no computer-related issues), and it doesn't feel the least bit slow ... actually faster than my prior stock-equipped T-5 notch ... but probably more due to having 4.10's and lots of weight reduction versus 3.08's and all the trimmings. :D
I'd be looking for vacuum leaks or something amiss in the ignition or fuel systems, instead, as a cause of the perceived slowness.
Thanks guys - I have no computer codes showing - car is a fresh rebuild and I was just thinking that the computer could be one of the concerns - car is a dog... Still working many angles on this one - got it moving a bit better yesterday but unable to work on it since then.
