1994 351W Roller Engine Question
  • Thread starter Thread starter armand67Fstback
  • Start date Start date Nov 5, 2010
1 of 2 Next Last
armand67Fstback
146
  • Nov 5, 2010
I needed some advice on a roller 351W. From what I could find these are supposed to have a compression ratio in the high 8's. From the factory they had the E7TE heads. What combustion chamber size do these heads have?
If I get one of these stock engines with 80K miles can I install 58cc AFR 205 heads and a moderate cam. Will this be a good street engine?
I want to purchase AFR 205 heads so I can use them now and later on down the road when I have the $ to build a 408W.
Let me know what you guys think about this stock short block with AFR 205 heads with 58cc combustion chambers.
D
D.Hearne
11,730
south louisiana
Nov 6, 2010
  • Nov 6, 2010
E7's have 64 cc chambers.If it has a roller cam it will spec like this: 256/266* advertised duration lift is .422/.473 with a 116* LSA Running it with 1.7 rockers will boost the lift by .030 at the valve. Works great with a carb.
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Nov 6, 2010
  • Nov 6, 2010
Armand--I'm just curious what the 351 came out of. I'm debating a build-up of my 302 (which needs a total rebuild) vs. going w/ a 351.
D
D.Hearne
11,730
south louisiana
Nov 6, 2010
  • Nov 6, 2010
The roller 351's are found only in pickups and vans ==== 94-97 year model.
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Nov 6, 2010
  • Nov 6, 2010
Thanks, D Hearne!
armand67Fstback
146
  • Nov 6, 2010
My dad found two at a junkyard, so I have two to choose from. I am driving 3 hours to go see which of the two looks the best.
If the stock heads are 64cc what will the AFR 205 head with 58cc combustion chambers do to the compression?
Thanks for the replies so far, I am glad to see I am on the right track. Trying to make the best decisions and save $. Thanks D.Hearne for the specifications on the heads and cam.
CarfreakGT, as D.Hearne mentioned the engines are from a F250 truck or an E250 van. My information gathering tells me it is a bigger displacement version of the 5.o and with a stronger block and a roller cam like the 5.0.
D
D.Hearne
11,730
south louisiana
Nov 6, 2010
  • Nov 6, 2010
These also came in E & F 150's. I had one in a 95 E150 van
armand67Fstback
146
  • Nov 7, 2010
AFR 205's
If the stock heads on this engine are 64cc what will the AFR 205 head with 58cc combustion chambers do to the compression and drivability?
D
D.Hearne
11,730
south louisiana
Nov 7, 2010
  • Nov 7, 2010
I don't have a calculator handy, but the compression ratio will go up by about a half point I'd guess. Driveability will depend on the cam you run with it. And intake/carb combo (if you go that route)
D
D.Hearne
11,730
south louisiana
Nov 7, 2010
#10
  • Nov 7, 2010
  • #10
I don't have a calculator handy, but the compression ratio will go up by about a half point I'd guess. Driveability will depend on the cam you run with it. And intake/carb combo (if you go that route) The bigger the cam, intake (plenum volume as in dual plane vs single plane) and carb, the higher up the rpm band you move the power as a general rule.
frdnut
20
Ontario ,Canada
Nov 7, 2010
#11
  • Nov 7, 2010
  • #11
The extra compression will be a nice bonus...One thing to watch is your piston to valve clearance..Those 205 heads have much bigger valves than the stock ford heads..
armand67Fstback
146
#12
  • Nov 8, 2010
  • #12
D.hearne and frdnut thanks for all of the good information.
The engine was torn down to the short block and everything looks good on the engine.
I have about $2200 to get it on the road. The two options I am looking with this amount of $ is an Air Gap RPM with Fast EZ-EFI.
The second is a carb, cam, and AFR 205 heads.
Would I treat the EZ-EFI like a carb and get a dual plane Edelbrock Air Gap or would it be best to use a single plane with this EFI system?
D
D.Hearne
11,730
south louisiana
Nov 8, 2010
#13
  • Nov 8, 2010
  • #13
The EFI systems all work with a single plane. I don't think I've seen em with a dual plane. If you go carbed, highrise dual plane is what you want. And donlt go overboard on a carb. Smaller is better with a carb. With a 351, no bigger than a 750 (vacuum sec) is max. I'd go with a Holley 670 Street Avenger.
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Nov 8, 2010
#14
  • Nov 8, 2010
  • #14
D**n you, Armand. I was set on a 302 build. Now, I'm re-weighing my options and considering a 351. Local Pull-a-Part has (5) E-250's from 1995-97.
frdnut
20
Ontario ,Canada
Nov 8, 2010
#15
  • Nov 8, 2010
  • #15
I guess it depends on what you want.Excellent driveability or brute power?
As for what intake to run with that EFI setup why not contact the manufacturer and ask them what they recommend?
armand67Fstback
146
#16
  • Nov 9, 2010
  • #16
351W
CarFreakGt, it is funny to see that I am influencing others I know what you mean, I have a 1991 5.0 HO and the 302 that was in the car, but I decided to buy a roller 351W.
That means buying another intake and most likely headers. I already have ceramic long tubes for the 302 and FRPP shorty headers for the 5.0L. I think it will be better in the long run. Are you going to go 351W or stroke it to a larger displacement?
Let me know if you get it, we may need to share information to get these engines tearing up some asphalt.
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Nov 10, 2010
#17
  • Nov 10, 2010
  • #17
Armand--I'm going to stay w/ the 351 as is, for now. I found one locally already mildly built that will help me get mine up and running after the suspension rebuild and engine transplant. Mine's been sitting so long, I want to be able to take my boys out in it on nice days, since they're getting old enough to ask about it and enjoy it.
Now, I can't say that down the road that I won't be exploring grander plans for the engine. But, for the price I'm getting this one for, I should be able to sell my 302 (which needs a total rebuild), Holley carb and Weiand intake separately, and a set of headers to make it a wash. Basically, an even trade for the 351 (no rebuild necessary), for those parts that I listed. And, no digging into the suspension and tranny fund!
Rick 91GT
Mustang Master
95
99
PA
Nov 13, 2010
#18
  • Nov 13, 2010
  • #18
The large intake valve in the 205 may not have enough radial clearance on that piston, you'll have to check the clearance....
Compression will change by about .8-.9 with the 58cc head..
armand67Fstback
146
#19
  • Nov 13, 2010
  • #19
Clearances
Thanks for the information, I will make sure to have the clearance checked, if it does not work then I will just go ahead and rebuild the engine locally so that these heads work.
If it does work, the increase in compression will be a good boost.
armand67Fstback
146
#20
  • Nov 21, 2010
  • #20
Pistons and Valve Clearance
I currently have the 351W (F4TE) down to the short block. Does anyone know if the pistons on a 1994 F4TE engine are cast or forged?
I was also wondering if the AFR 205's need some valve clearance, can the pistons be notched more without removing the pistons from the block?
The pistons have a good size square shaped notch in the center from the factory.
1 of 2 Next Last
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 9:34 PM
Qtrhrse23
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
