1994+ Meziere WP374R Electric Water Pump
jwpray84
Hey!
You are looking at a used but in great condition Meziere performance electric water pump for 1994 and later small block ford engines. The pump is in great condition and runs just as it were out of the box. This unit retails for USD 600+. Im asking 400 OBO, Buyer pays shipping. Pictures available upon request. For more details, here is the factory description:
WP374R - Street Style Electric Water Pump
Innovative design makes for an easy installation. Unbolt your factory pump and bolt on an easy 11-14 horsepower with our street style water pump. An idler is incorporated onto the pump so your belt routing remains in its stock configuration. American made with quality far superior to any other performance aftermarket company, we build our water pumps with pride right here in the USA. Don't be mislead by inflated flow numbers and competitors' outlandish claims. Our 300 series pumps move more water and produce more pressure than any other electric pump on the market. That means better protection for your high horsepower, high demand engine! Our 2 year, unlimited mileage guarantee and full satisfaction money back guarantee should convince you that buying Meziere is buying value!
This water pump model features:
Fits small block Ford 5.0 model engine with 1994 1/2 and later timing cover (short pump style) or Ford Motorsport timing cover
Idler design lets you keep all of your serpentine belt driven accessories
Suitable for street or drag strip use – 3000+ hour life expectancy
Show quality red anodized finish - hard clear anodized pulley
Standard motor provides 55 gallons per minute free flow rating
Ports provided for heater and bypass
Inlet fitting, heater and bypass fitting included
Stainless steel large diameter main shaft with high performance ceramic seal
Alternate inlet fittings available
Technical Specifications:
Belt Drives: If you are running a cam belt drive on your small block Ford, you will most likely need the WP173 pump. This pump will not fit Yates, Danny B, Jessel, or Race Master belt drives.
Finishing The System: This pump is supplied complete with gaskets and fittings. No additional items should be necessary.
Amperage draw: Under normal use the pump will draw 11-12 amps.
Overall Height Dimension: The standard pump is 4.75" long from the mounting surface to the tip of the pump.
Pump Weight: This application weighs 6.9 lbs.
16 volt systems: When purchasing a pump for a 16 volt system we recommend the 16 volt optional motor on our pump. The 12 volt pump will work for limited use applications.
Additional Notes:
The standard 35 GPM pump is suitable for normally aspirated engines up to 650HP. Supercharged, turbocharged and high compression, high horsepower applications should use the 55GPM High Flow pump only.
The small block Ford engine has gone through several design changes at the factory since its inception. There are two different 55 GPM pump models that may be right for your engine. For more information regarding small block Ford applications and how to tell which pump is correct for you, please see our SB Ford addendum sheet.
