1995 Mustang gt.. Harmonic balancer?
bigm_05
9
Illinois
When i put my car into park it shakes so bad as if someone is outside pushing on it.. I have not started since.. and im not sure wut to do or where to check? Can anyone help plz.. Places to look?:bang:
The harm. ball. is common for causing the issue and common for failure on the 94-95's. For the stock HB there is an inner and an outer ring with a rubber piece in the middle. This rubber piece will work its way out and either it will be sticking out alot more than the rest of the rubber (not uniform like it should be) or the outer ring will spin and cause it to be off.
Look for the rubber being un-even, or put a timing light on it...if the light looks like its way off (stock is around 10*) then it has spun.
Either way its prob. a good idea to replace as it can cuase some bad wear on bear. and such.
I would also suggest not getting an autozone or like replacement. I went threw 2 or 3 of them in short order. I went with a pioneer unit (non-sfi) a few years ago and no problems since.
IF it is the h.b. deff go with a pioneer (easy install and a great piece), just like bmac50 said - i ended up changing 2 napa ones in a matter of 6 weeks so....
im a lil off topic up top but i had to support the pioneer's - im not a 100% its ur h.b. tho - the car would give you a bad vibration in D if it was the h.b.
good luck !!!
