1997 mustang brake lines
Epicwrightbro
Michigan
Hey guys, upcoming car enthusiast here that has been fixing up my 97 v6 (that I plan on swapping out) until I ran into a problem after changing the front struts. I just so happened to accidentally put too much tension on the right caliper and busted my brake like under the radiator. I’m trying to find the replacement lines but are all coming up without abs, while the gt versions just so happen to come with it. Will the gt lines fit the same with abs or do I just buy the ones without abs? I’m lost.‍
Do you have abs or no? I believe its an option in 97 or maybe no v6’s had ABS in that year im not sure.
Anyways is it possible to just splice in a piece with unions if the whole line isn’t that bad?
