1998 GT REAR END NOISES
banks98stang
57
OK SO MY REAR END ITS MAKING NOISES. I CAN FEEL MOVEMENT AND CLUNKING NOISES WHEN I AM COMING TO A STOP OR SOMETIES WHEN TAKEING OFF. IM GOING TO GET IT REBUILT BUT IM JUST WONDERING IF ANYONE KNOW IS I COULD BE SOMETHING ELSE
U-joints usually make clunking noises esp when changing from from driving to coasting. The other give away is changing from reverse to drive at a stop.
The wheel, pinion, and carrier bearings can made distinctive noises that can diagnosis the problem. A careful description of the noise and when it occurs can help.
U-joints are often one of the weakest link in the drive line. Esp if abused.
U-joints are much easier to install than rebuilding a rear end (just did one myself).
How many miles? Have you considered pulling the cover to inspect the gear oil and carrier bearings?
They make a clunking or clicking esp when shifting from reverse to forward.
If you take the drive shaft off, you may feel binding in the joints as they are moved by hand. Any binding that can be felt by hand means the U-joints are bad.
It is also possible that the worn out U-joints will feel very loose and sloppy if moved by hand.
However, the cost of U-joints is not that high. I would be inclinded to replace if high mileage (or abused). Esp after going to the trouble to remove the drive shaft.
While a lot of things are possible, for the Pinion bearing to make a CLUNK, it would have to be very loose. So loose that visible in/out play would be evident.
Grab the pinion and try to move it in and out. If it moves at all, there is no pinion bearing preload. This is bad.
U-joints tend to make a more distinctive click/clunk. The noise pinion bearings make is less distinctive. It is higher pitched because it varies with engine speed.
Bad Carrier bearings are lower pitched noise because it varies with the speed of the tires.
How many miles on the car? When was the last time the rear-end was serviced? If more than 100k miles, recommend a service. Almost all rear-end problems will become evident upon visual inspection of the gears and oil.
However, when abused, U-joints fail at a much higher rate than the rear end. IMO, the first inspection should be U-joints. Then move onto the rear-end.
From the Ford Service CD:
Universal Joint (U-Joint) Wear
Place the vehicle on a frame hoist and rotate the driveshaft by hand. Check for rough operation or seized U-joints. Install a new U-joint if it shows signs of seizure, excessive wear, or incorrect seating. Refer to Section 205-01 .
Axle Noise
NOTE: Before disassembling the axle to diagnose and correct gear noise, eliminate the tires, exhaust, trim items, roof racks, axle shafts and wheel bearings as possible causes. Follow the diagnostic procedures in Section 100-04 .
The noises described as follows usually have specific causes that can be diagnosed by observation as the unit is disassembled. The initial clues are the type of noise heard during the road test.
Gear Howl and Whine
Howling or whining of the ring gear and pinion is due to an incorrect gear pattern, gear damage or incorrect bearing preload.
Bearing whine is a high-pitched sound similar to a whistle. It is usually caused by worn/damaged pinion bearings, which are operating at driveshaft speed. Bearing noise occurs at all driving speeds. This distinguishes it from gear whine which usually comes and goes as speed changes.
As noted, pinion bearings make a high-pitched, whistling noise, usually at all speeds. If however there is only one pinion bearing that is worn/damaged, the noise may vary in different driving phases. If pinion bearings are scored or damaged or there is a specific pinion bearing noise, new pinion bearings must be installed. A worn/damaged bearing will normally be obvious at disassembly. Examine the large end of the rollers for wear. If the pinion bearings original blend radius has worn to a sharp edge, a new pinion bearing must be installed.
NOTE: A low-pitched rumble normally associated with a worn/damaged wheel bearing can also be caused by tires.
A wheel bearing noise can be mistaken for a pinion bearing noise. Check the wheel bearing for a spalled cup, and spalled/damaged rollers. Check the wheel bearing for rotating smoothness and end play. Install a new wheel bearing if any of these concerns are detected.
If the wheel bearing is damaged, the roller surface on the axle shaft may also be damaged. Install a new axle shaft if any damage is detected.
Chuckle that occurs on the coast driving phase is usually caused by excessive clearance between the differential gear hub and the differential case bore.
Damage to a gear tooth on the coast side can cause a noise identical to a chuckle. A very small tooth nick or ridge on the edge of a tooth can cause the noise.
Clean the gear tooth nick or ridge with a small grinding wheel. If the damaged area is larger than 3.2 mm (1/8 inch), install a new gearset.
To check the ring gear and pinion, remove as much lubricant as possible from the gears with clean solvent. Wipe the gears dry or blow them dry with compressed air. Look for scored or damaged teeth. Also look for cracks or other damage.
If either gear is scored or damaged badly, install a new ring gear and pinion.
If metal has broken loose, the axle housing must be cleaned to remove particles that will cause damage. At this time, any other new parts in the axle housing must also be installed, if necessary.
Knock, which can occur on all driving phases, has several causes including damaged teeth or gearset.
In most cases, one of the following conditions will occur:
A gear tooth damaged on the drive side is a common cause of the knock. This can usually be corrected by grinding the damaged area.
NOTE: Measure the end play with a Dial Indicator with Bracketry and not by feel.
Knock is also caused by excessive end play in the axle shafts. Up to 0.762 mm (0.030 inch) is allowed in semi-float axles. The frequency of the knock will be less because the axle shaft speed is slower than the driveshaft.
Clunk is a metallic noise heard when the automatic transmission is engaged in REVERSE or DRIVE. The noise may also occur when throttle is applied or released. It is caused by backlash somewhere in the driveline or loose suspension components; it is felt or heard in the axle. Refer to Total Backlash Check in this section.
Additionally, clunk may be heard upon initial drive-away. This occurs as engine torque shifts vehicle weight, forcing changes in driveline angles, preventing the driveshaft slip-yoke from sliding on the output shaft. To correct for this condition, lubricate the slip-yoke splines.
ok i bought the car from a lady and her son the car has 97k miles on it now since then ive done the fuel pump myself and the plugs oil. i bought the u joints and havent had time to make it to my uncles shop or house ( he kinda lags on me). i havent serviced the rear end due to money issues i been doing lil by lil.
now if i do the gear inspection im going to need the gasket and fluid how much fluid and what kind.
i only here the noise when i am going slow in reverse and turning the wheel it like a clunking grinding noise or sometimes when im coming to a stop i can feel something from the rear end thats pushing forward
sorry im not very good at description
Don't need a gasket. Use RTV silcone. Clean the old silcone and use a thin bead all around including the bolt holes. Torque the bolts to 24 foot pounds. Don't over torque.
2 quarts 75W-90 and 4 oz of friction modifier. Fill till 1/4" to 1/2" of the bottom of fill hole. Should have a few ounces left over.
Inspect the axle seals at the same time. Much easier to replace when oil is already out than later.
Binding/clicking/popping while turning is usually limited slip (T-LOK). Some binding while slowly turning is normal.
Feeling the axle move coming to a stop could be bushings, shocks, quad shocks.
It could also be brakes. The design of the Rear Mustang brakes are bad about the slid pins galling to the bracket. Water gets in the seal and freezes (galls) the sild pins the to bracket. This results in uneven application of the braking force (more clamping on one side than the other). If one brake side is working and the other not, this could cause the axle to shift forward on the side that is not working.
Look for uneven ware in the rear brake pads. The slid pins MUST move freely.
If you only hear it when turning it sounds like the limited slip ("Traction Lok") is binding a bit. When you turn corners in the car, the outer wheel moves a further distance than the inner wheel. In open differential cars, this is automatic. In a limited slip car, where the two axles are tied together mechancally, for this to happen the differential must allow for "slip" between the axles and for the slip to be invisible to the driver, it must do so without binding or chattering.
This sort of chattering might be cured simply by a fluid swap: 75W140 synth (that's what the later cars call for, not sure about your 98) and the all-important bottle of "friction modifier" wmburns talks about:
It could also point to a possible TLok rebuild due to damaged friction or steel plates in the clutches. It's cheaper to try a fluid change before getting into the mechanicals of the rear axle.
if you any 98, then stick with 2 quart of synetic 75w90 Mobil1 ........ and that little bottle of ford friction additive, and make sure u use grey RTV only, so gasket need for rear diff cover.
